Originally Posted by simon_templar_32
I had an XA2 for a while and liked the Reon. So do you have some experience with the HC6000 and lip sync when engaging the Reon?
It would seem for me that even minimal AVR processing (using player decoding sent over HDMI) might include LFE boost, bass management, DAC, and 5.1 to 7.1.
Not with the HC6000. Never had an audio sync issue with it.
The HC6000 in particular does a real good job upconverting , DVD cable and sat 480i images to pretty good images.
I have used an HD XA2 with a HC6000 using both component (non HD XA2 Reon upconverted output) and HDMI (HD XA2 Reon upconverted output) to a HC6000 and to analog 5.1, optical, coax and HDMI audio inputs into several AVRs and never got a lypc sync issue. Not sure why but the HC6000 seems more stable in its audio sync. Using mostly Denon AVRs.
The HC5500 seems like it would be as stable.
