I am looking for the best headphone setup with a PS3, in terms of sound quality.
-I am looking for a setup that won't have any "white noise" or such.
-I also read that the PS3 supports 24bit or Hi-Def audio quality, but only can be heard through use of an HDMI 1.2a or better receiver.
I heard it from this thread
head-fi.org/forums/f46/au...roblem-330235/
-I have an HDMI 1080p Display and it has a headphone jack on the side of it,
I'm not sure of how to get a good setup using that jack.
So I have 3 questions.
1. For movies and gaming, should I get surround sound?
If yes, should I get an surround sound adapter with stereo phones?
or a 5.1/7.1 Headphone?
2. Which setup is better?
a.PS3 >-(HDMI Cable)->HDMI 1.2a(or better) Home Theater Receiver >-(Toslink Cable)-> Optical decoder>-(Cable depends on the headphones)-> Headphones
b.PS3 >-(HDMI Cable)->HDMI 1.2a(or better) Home Theater Receiver >-(Coaxial Cable)-> Amplifier>-(Cable depends on the headphones)-> Headphones
c.b.PS3 >-(HDMI Cable)->HDMI TV(has headphone jack on the side, no inbuilt audio)>-(Not sure which Cable)->Amplifier>-(Cable depends on the headphones)-> Headphones
d.PS3---Toslink---Mini Toslink Adapter---JVC---?---Headphone amp---DT880S
I got that setup from this thread
head-fi.org/forums/f4/rec...17/index3.html
e. Something else that you can recommend...
3. How can I use an headphone and a microphone with the PS3 at the same time?
