This is probably a theoretical question, but I believe it has afflicted the end users since Day One.
With today's Home Theater set-ups, quite often the use of one or more long HDMI cables is inevitable. This means that the cables are thick and heavy and that the HDMI jacks of the devices suffer from a strech or an angular force, depending how the cable runs from one device to another.
I have seen an advertisement of a cable-making company that has integrated a computer-like screw, which provides some decent stabilisation of the plug, but this design is out of specs and certainly it has not been adopted by the consumer electronic device makers.
The question goes to the HDMI Organization:
How do you think that this problem can be solved?
Moreover, I have - the same - question for the AVSforum members, but from a practical point of view:
How do you solve this problem with your gear?
From my side, I have tried several patents, but what I find more handy is the use of the well known plasticised wire (which we frequently use to tire-up the loose cables inside a computer box). I use a piece of a suitable length and I try to find a steady pair of points on both sides of the jack, preferably a little higher, and I am trying to support the extra weight of the cable, by hanging it from the wire, which then is firmly attached and tightened on the pair of the above mentioned points.
But this is neither always possible nor easy to be done.
Therefore the question remains: How do you solve this problem?
