AHHHH! I'm going nuts!!!
So I read the manual front to back last night! I want to play with the CUSTOM MCACC settings using different memory slots (M1, M2, M3 etc...)
I ran Auto MCACC and saved to M1 (memory 1). I then copied M1 to M2, M3, and M4.
What I am hoping to accomplish is different speaker settings for each MCACC preset. For example, M1 (memory 1) would have the default settings that Auto MCACC sets up for me where it left All speakers LARGE.
M2 (memory 2) I would also like to use the default settings from Auto MCACC; EXCEPT I would like to set all speakers to SMALL.
M3 (memory 3) I would like to use the default settings from Auto MCACC; EXCEPT I would like all speakers set to SMALL BUT I need my subwoofer "SW" setting set to "PLUS" instead of "YES". (I want to change the subwoofer setting here because I don't get Dolby etc... on my TV broadcasts, but would still like sound to come out of Subwoofer when watching movies on HBO or Pay-Per-View)
I was all excited and spent about 30 minutes running Auto MCACC, copying the memory from M1 to M2 and M3. I then hit the MCACC button on receiver and switched to M3 (memory 3) and then went to settings and changed the subwoofer "SW" setting to "PLUS" - BUT when I went back to M2 (Memory 2) to watch a Movie from my DVD player --- my subwoofer didn't sound like it was performing properly. I went to check the M2 (Memory 2) speaker settings and found that the subwoofer setting "SW" was changed to "PLUS".
So are the SPEAKER SETTINGS a global setting? Meaning that you can't change the speaker settings for individual MCACC memory slots? If you change them on M1, they automatically apply that setting to memory slots M2, M3 etc... ???
If thats the case I am a little disappointed BUT am still very pleased with the receiver!
SOMEONE HELP ME OUT! Thanks!
. I'm not bothered by it but do agree it's a function that would be useful.
Again, you will lose all Audyssey capabilities and will not have Audyssey Dynamic EQ and Audyssey Dynamic Volume capabilities by making any changes to the EQ. OK, so you decide you will leave Audyssey EQ set rather than making your preferred EQ tweak, because you want the Audyssey room & speaker calibration, Dynamic EQ, and Dynamic Volume capabilities, and you decide you will just use bass/treble controls to adjust the tone to your preference. Another big problem here. Not only does this limit your tweaking to a couple broad frequency ranges, but if you are using Audyssey Dynamic EQ, you can NOT adjust the tone controls either!
