AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official VSX-1018AH-K Owners, Reviews, and Comments Thread!
The Official VSX-1018AH-K Owners, Reviews, and Comments Thread! - Page 196
post #5851 of 5904
Any device out there where I can use this receiver and still 3D video passed to the TV with HDMI
post #5852 of 5904
I'm looking into this scenario myself. But to get 3D pass-through, you're going to have to go directly into the TV input and bypass the receiver.
I was thinking about using a 1X2 HDMI splitter (that is 3D-certified). The idea is you send one out to the receiver and one directly to the 3D TV. So for regular Blu-ray use, you run through the receiver as usual. But for 3D discs, you switch to the "direct" input on the TV and use the PS3's optical out for audio. If the HDMI "lowest common denominator" factor comes in to play, I'm thinking you just unplug the cable sending to the reciever when watching 3D to take it out of the equation. Obviously, you lose your lossless sound on your 3D titles - but I don't see any way around that.
All this is theory at this point - I'm still deciding whether to get a new 3D TV. But I've been told from others on the forums that it should work. Has anyone else here tried a similar setup?
post #5853 of 5904
Originally Posted by rahzel View Post
Has anyone played Transformers Dark of the Moon (7.1 TrueHD) on their 1018? Does it display all 8 channels on the display, or does it display only 6ch TrueHD?
If no one has played Transformers DotM, what about other 7.1 TrueHD tracks? This is the only 8ch TrueHD track I have and it's only displaying as 6ch on my 1018. DTS-HD 8ch displays all 8ch, but not this TrueHD track.
is the bluray player going directly into the BD hdmi input?
post #5854 of 5904
I get stung buying new equipment every few years as tech "advances"...so Ill probably just get a new receiver..if I run optical for audio I lose the lossless sound options.
post #5855 of 5904
I'm thinking the same thing, but I may just get a dual hdmi out bluray player and leave my ps3 for games. When i bought my 1018 I really believed I wouldn't need a new one for at least 7yrs, now that has been cut in half.
post #5856 of 5904
Your concern about the lowest common denominator is real. I have not seen that anyone has found a splitter that works. You get the same output from both legs.
post #5857 of 5904
If the output was the same could one not run a hdmi to the tv and one to the receiver for sound?
post #5858 of 5904
The TV is 1.4 and the receiver is 1.3 The same output from the player won't work with both. That's why there are players with dual HDMI outputs.
post #5859 of 5904
Well I wouldnt need 1.4 for sound and the TV is 3d so couldnt each device use the signal that they are capable of.TV for video and receiver for sound
post #5860 of 5904
No. The 1.3 device needs to tell the player to send a signal it can process, which is not the same as the 1.4 signal the TV needs for 3D.
post #5861 of 5904
Ok then how would a device with 2 hdmi outputs help since both signals would be 1.4...not really any workaround
post #5862 of 5904
It's what the players like that (like this Panny) were designed for. I was just trying to save $180.
post #5863 of 5904
So with that setup I can keep my old receiver for sound and send one to the tv. Will the receiver be able to use the audio portion in 1.4?
post #5864 of 5904
Yes.
I have the Panasonic DMP-BDT310 and lossless audio is produced from the VSX-1018AH-K and the 3D video is viewed from my Panasonic 55GT30.
Considered both the Pioneer BDP-53 & Oppo BDP-93, but went with the Panny 310 due to the cost factor...glad I did.
post #5865 of 5904
Thanks...Tom
post #5866 of 5904
The TV and player communicate using 1.4 for 3D while the receiver and player communicate using 1.3 for audio. The player communicates with each device independently.
post #5867 of 5904
Hello, it has been quite some time since I have been on AVS Forum! I think that is a good thing in the fact that I have not had any problems with my A/V equipment... until now!
I believe that I have isolated the problem to my 1018. For the past 3-4 months, when I turn on my system using my Logitec remote it takes forever for the TV to turn on. I see that the receivers HDMI light blinks on and off and the TV attempts to come on but I hear sound but the picture flickers on and off and most of the time goes to snow and then the snow sound will come through the receiver very loud. I hear the receiver click several times, then the picture on the TV will finally come on. It has progressively gotten worse and makes a lot of noise before it comes on.
I finally had enough and pulled out the manual to see if there was something on it. I ran across a section on the HDMI Control on the receiver. It said that unless you have a Pioneer TV this control should be off. Well when I checked, it was ON! So I turned it off and for 2 days everything was great! TV turned on normally, right away, great!
Well, this afternoon it started doing it again! I checked and the HDMI control was still off. HELP!!!
post #5868 of 5904
Maybe try a new or different HDMI cable
post #5869 of 5904
I have already replaced the output hdmi cable coming from the receiver to the tv and it does the same thing. Is it some sort of scanning thing? It worked for years then worked for 2 days so I am fairly certain it is the receiver. Once its on everything is fine.
post #5870 of 5904
Good and bad news... the good is it is not the receiver! The bad is it is the TV. During my research I found that several Samsung LCD and other sets have problems with their capacitors and they are known to blow or leak causing the problems that I have been having. Samsung is sending a local authorized repair person in my area to replace them. Glad its not my Pioneer!
post #5871 of 5904
Thinking about getting the Sony BDP-S480 (on sale at Fry's for $99) for use as a inexpensive SACD player.
Will be using HDMI to connect with the VSX-1018AH. I understand that my TV may need to be on in order for the HDMI handshake to work.
Are there any other issues/frustrations that may occur?
post #5872 of 5904
My system has worked fine for a few years, then lost all audio. Took AVR out of rack to take to Pio service center, but tried it one more time while on bench, had sound. So back in rack it went.
I have a BD35 BD player connected to the AVR at the BD input via hdmi cable.
I have an htpc connected at HDMI 1 input via hdmi cable.
Both have video.
Only the htpc at HDMI 1 has audio.
Swapping the connections at rear of the 1018 still has video at both, but still only audio at HDMI 1, so this tells me the source units not the problem.
So my problem is - BD input no longer passes audio.
Any thoughts?
I went through troubleshooting, finally did a factory reset, still no joy.
Another question;
Does the BD input have any special features I would lose if I simply plugged the BD35 into HDMI 2 input? I've never used this one but assume it's functional.
post #5873 of 5904
nope... go ahead and use whatever hdmi input works...
post #5874 of 5904
So using HDMI 1 and 2, all good.
Guess if I want to add a 3rd HDMI source I'll have to buy a new AVR. But no plans to do so.
post #5875 of 5904
cool...
or buy a cheap hdmi switch...
post #5876 of 5904
that's a 1019 you linked to...
i wouldn't...
post #5877 of 5904
This is an odd problem that i just remembered that i have. I have had my 1018 for a couple years now and recently got a real sub, Polk PW505. However, when I plug it into the subwoofer port on the back of the 1018, i get no signal sent to it at all. i currently have it plugged into one of the other pre-amp outs and it works fine....but i cant do MCACC with a sub as it cant detect anything from it. any ideas at all?
post #5878 of 5904
Having the EXACT same issue:
Things I've tried:
- Setting all speakers to SMALL, SW to ON - All X-Over freq settings.
- All possible combinations on the Sub itself to get volume up.
- Checking the line input on the sub.
- LFE settings are correct, DRC is correct, receiver setting should be correct
- Full reset of the Receiver
- Testing it off say a centre channel to see if there's something wrong with the pre-outs, and nothing :/
On searching and scouring the web - everything points to my own stupidity here, and some glaring issue with the settings, however having never used a sub with the system before, I'm fearing that it could be the sub preout is bust.
post #5879 of 5904
Hello there,
I'd love for some input from other VSX 1018 owners. Basically we're now moving and in the current house I put all the speaker wires and everything in the walls when we finished the basement. I'm going to leave my HKTS 18 setup and purchase a new setup.
The two systems I'm looking at are the Polk Audio TL350 or the Energy Take Classic 2. The new house it will be in a fairly large room. I don't ever blast the system but I want to be able to hear it nicely with some oomph! I also don't want to put a massive strain on the receiver. In both cases I'd look to upgrade the 5.1 setup to a 7.1.
I'd appreciate any feedback as I'm not an audiophile but love my movies to sound great!
post #5880 of 5904
i have a set of polks on mine and it sounds great at -40 and at +5
