AVS › AVS Forum › Display Devices › CRT Projectors › Nec Gp3000
Nec Gp3000
post #1 of 6
Stopped powering up. No lights on the back panel. Where the heck is the primary fuse on this thing and how do you access it? Thanks for any help.
post #2 of 6
Chances are the main power supply has blown it's proprietary chips within the power supply and it has died. There is one fuse in teh SMPS, but guaranteed it's OK. I have one working GP3000 in minty shape left that I'll sell cheap if you're interested. I can try to repair the SMPS, but chances are I can sell you a whole other set for less than it would cost to repair the supply.
post #3 of 6
Do a search in the archives. THe gp3000/5000 are known for this problem.
No fix for it
post #4 of 6
Dang. Curt, has the unit you have been modified to prevent the dreaded Hybrid failure?
Anybody want a dead GP3000?
post #5 of 6
The chip in question is made of "unobtanium"
Martin
post #6 of 6
Nope. It works, but who knows for how long. It's not worth spending 2 hours to go through the set. But I'll sell it cheap. As is.
  Back to Forum: CRT Projectors
