I am looking to program my Samsung PN50A650 into my AVR and I can not seem to find the code. Does anyone know the remote code for the AVR254 for the Samsung PN50A650?
BD6675
BD6675
). Could this be the AVR? I guess I will figure it out if I run video directly to the TV...I really think it's got to be the DVR and was hoping for confirmation from someone who has had this issue.
) and the pixilation issue could be either the box or the cable. The Dvr's get really hot and if not ventilated good it will pixel ate. I to have a dvr and since the latest firmware upgrade the box and avr have worked better but every once and a while it may hiccup. You could either run component from the dvr to the avr and out Hdmi with optical for audio or if you're feeling frisky.....you can change the setting in the dvr to only output 1080i/720p that way there is no going back between HD and SD. If the dvr is on hit the cable button on your remote and then hit power and then hit the menu button. Scroll down to the 4:3 override switch it to off. Do not go into the HDMI setting it will screw the box up and you will need another one. You could change the output of the HD between 1080/720 etc. I hope this helps....
