Originally Posted by jzonta
Hey guys i need some help. I am new to the forum and I have tried to search the whole internet calibration settings. I own a AVR 154 and don't have the EZ set thing. I am totally lost on the calibration menu and was hoping i can get some advice or some of your settings. Here is my setup:
I have the AVR 154 connected to a harman kardon HKTS-18 5.1 system and a ps3 via optical cable. My speakers distances are about 9ft from where I sit. I know its a matter of preferance on the calibrations but could i please get some suggestions? thanks alot!
The HKTS-18 uses the HKS 9 speakers as satellites. The frequency response is 105-20khz -6db. You should set your crossover for all of the satellites to 120hz so that you send all of the other bass info to your sub. You can set the sub to 10" as that is what it is, although to be honest I don't know what that setting does.
For the level settings just listen to the test tone and try and make the volume the same for each speaker including the sub. Good luck.
