Originally Posted by myerss
After spending an entire day with the 254 I'm on the fence if I'm returning it or hoping that a firmware update fixes the quirks. The 254 keeps having sync issues with HDDVD. I lost video for about an hour from HDDVD, although the audio was still coming through. I've given up on the component to HDMI conversion, too much of a headache for me to worry about (I'll just switch inputs on the projector). Blu Ray and Satelite seem rock solid, only HDMI sync problem has been with HDDVD.
One other quirk, I was watching AVP Requiem (only Master Audio disc I have) and I lost the dialog. Effects sounded great but all the voicing was at a whisper. Ended up looking back into the speaker setup and the center channel was down 12 db from my original setup.
I'd box it up and send it back, but when it is synced up the sound is amazing.... I keep wondering if this is an HK problem or possibly my display (Sharp XVZ-12000 MK2 Projector) since its DVI. I'd hate to send this unit back and have the same problems with an Onkyo 606/705?????
You might want to talk to H/K tech support before bailing on it. The HD-DVD HDMI issue is probably the fault of the HD-DVD player, not the H/K, and the center speaker level issue is probably fixable - no reason for it I can think of. If the 254 is like my 520 you may have to set and save speaker levels for each input individually - did you do that?
Sigh...
