AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Middle Atlantic Custom Faceplates
Middle Atlantic Custom Faceplates - Page 3
post #61 of 70
Originally Posted by Mr.Poindexter View Post
Racks are pretty well standardized so any 19" shelf should work with a middle atlantic rack or any other 19" rack for that matter as long as the rack is deep enough.
Should have been a little more clear, I'm talking about the custom faceplate to be used with any standard shelf. Or is the custom faceplate only to work with the RSH shelf only?
post #62 of 70
I explained a few posts back how this is possible, though of course not as the quick and preferred solution as getting the whole RSH package is. Most local machine shops have the ability for say $5-10 each to modify the tabs so that the faceplate can be flush-mounted over the face of your component if it is mounted on a standard shelf. If you do not already have shelves, or just a couple of them, then I doubt it would be worth your effort to try to circumvent it in this way.
post #63 of 70
Yeah, it really is best to just use the faceplates with the middle Atlantic rsh shelves.
post #64 of 70
I used the MA faceplates on the MA knock down shelves rather than the RSH version. The only reason was I had a few I bought dirt cheap and gave the plates a try. I think they were the KD line. The big thing is the sides have to come off.
http://www.middleatlantic.com/rackac...shelves3.htm#1
post #65 of 70
If you took the sides off then how is it screwed onto the rack?
post #66 of 70
Sorry you have to take the sides off to get the faceplate on, then reattach them to mount to the rack.
post #67 of 70
Hey Canucks! Where did you get your custom shelves?
post #68 of 70
Looking to get custom shelves/face plates in Canada, anyone?
stayonline.com won't ship to Canada.
post #69 of 70
Looking for Canada too!
post #70 of 70
I bought all my MA custom shelf / faceplates from Performanceaudio.com, and they appear to ship to Canada. Although you should certainly try sending a note to AV Science first... biggrin.gif
