Please describe how much buzz you hear from your Pioneer 9G model. Also, please note the model number.
AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer 9G "buzz" poll (Elite and non-Elite)
Featured Stories
AVS Top Picks
post #2 of 1627
6/29/08 at 2:58pm
- chadmak09
- Trader Feedback: 0
- offline
- 3,067 Posts. Joined 10/2007
- Select All Posts By This User
My 6020 Buzzes pretty loud.
Before getting my 6020 I had a 5080.
The 5080 I had barely buzzed at all. If you stuck your head behind the set you could hear it a little. But I never heard the 5080 buzz at normal viewing distance unless I turned the sound off and I listen really hard. So I never gave the buzz a second thought. And never worried about plasma buzz again.
Until I got my 6020.
It can be clearly heard from as far as 16 feet away.
The buzz changes pitch depending on the brightness of the content it is displaying.
And the 6020 is in the same spot, in the same room, on the same surge protector, and being heard by the same person.
So in my case, I can rule out room acoustics, Dirty Power (needing a power conditioner), Personal hearing differences, and the set needing to be broken in (buzz did not decrease after full break-in using evangelo's break-in dvd)
One thing that will help ALOT of people is to set the Power control to:
"POWERSAVE MODE2".
Yes it will decrease the overall brightness of the set but not by much.
Many can’t even tell when the powersave is set to mode2.
So powersave mode2 can be a complete fix for some people. Which is GREAT! Just having that choice helps alot of people and makes them feel much better.
I only use Powersave2 when I am surfing the net or doing anthing that is silent on the TV. During Silence it is just so annoying that I cannot stand it.
But powersave mode2 almost completly eliminates the buzz in my case.
During movie watching/sports/etc, I turn the powersave to "off". I want the TV to display its full brightness potential when watching movies/etc.
I can still hear the buzz during quiet scenes but have gotten used to it.
If you have a buzz problem then try Powersave mode2 and see if the decreased brightness bothers you. If it does not then use powersave mode2.
"POWERSAVE MODE2".
post #3 of 1627
6/29/08 at 2:58pm
If we are 'polling' for annoying noises ... I would like to know if any 9G's do this?
post #4 of 1627
6/29/08 at 3:14pm
- chadmak09
- offline
I have not experienced any noise when the set is in standby/power off mode.
Only when displaying content.
The buzz is at its worse when the screen goes to a bright white color or any "lighter" color.
I had thought that the buzz would decrease after break-in but I am finished with break-in and the buzz is the same.
Has anyone here personally had Pioneer replaced the set due to excessive buzzing?
I would like to hear personal stories from people who have actually contacted pioneer about this issue and what was done (if anything).
There seems to be some confusuion as to whether Pioneer considers a loud buzz a defect or not. I have heard from many owners that Pioneer will not replace an excessive buzzer, and I have heard from some dealers that they will and have done so in the past.
Is there a distance that the buzz can be heard that Pioneer uses to determine if the set has an anormal buzz or if its just the normal buzz that is inherit to plasma technology?
If so what is the distance?
Do they use sound measuring devises to determine if it is excessive or normal buzz?
-Thanks,
Chad
post #5 of 1627
6/29/08 at 3:17pm
post #6 of 1627
6/29/08 at 3:35pm
post #7 of 1627
6/29/08 at 4:17pm
post #8 of 1627
6/29/08 at 5:46pm
Model: 6020
Buzz: Extremely noticeable and extremely annoying when Power Save is Off. I sit about 12 feet from the set. Buzz can be heard from the back of the set (the power buzz) and from the front. So, buzz is being generated on both sides.
On Power Save Mode 2, I can't notice the buzz unless I set the screen to mute and affirmatively try to listen to it.
post #9 of 1627
6/29/08 at 7:30pm
- JimP
- Average Guy
- offline
- 13,901 Posts. Joined 9/2002
post #10 of 1627
6/29/08 at 8:56pm
post #11 of 1627
6/29/08 at 10:22pm
- DTV TiVo Dealer
- offline
- 4,878 Posts. Joined 2/2003
I have worked very closely on the buzz issue and have a few remarks to help clarify the issue.
First, the buzz is almost identical from panel to panel, assuming we are comparing same models/sizes/generations. So changing a 5020 for another 5020 will yield little too no difference. Some may report a different buzz and I would respond that if the panels are not placed exactly in the same position and the seating is not exactly the same you can't accurately compare the panels buzz.
Second, Very few people can even hear the buzz. That's because most of us we lose our ability to hear the oscillating frequency at about 30 yrs old. For example, I have enjoyed and been blessed with "Golden Ears" and could hear better than most. A 5020 user asked me to stop by to hear his buzzing panel and no matter how hard I tried I could not hear any sound whatsoever while the 28 yr old customer hear the buzz. The moral of the story is my "Golden Ears" are in their "Golden Years".
Third, all panel buzz, and it may be true that Pioneer panels may buzz slightly more than some other panels as they bond the filter on the single glass panel. Their are significant image quality advantages in Pioneer design.
Forth, The radiation pattern is very weak and small and is located directly in front of the panel and can reach somewhere between 6' and 14'. So adjusting the height and angle of the panel can eliminate the buzz.
Fifth, with any background noise or with the volume on even at a low level no one can hear the buzz.
Hope this helps.
-Robert
Hope this helps.
-Robert
post #12 of 1627
6/30/08 at 12:48am
- Waboman
- License to Chill
- online
- 5,413 Posts. Joined 9/2005
Great post! However, when I had my 8g 150FD, when listening at low levels, the buzz was always there. I did notice after time I got acclimated to the buzz and didn't notice it as much. But it was still always there. I hope it isn't as obtrusive in the 9gs. I'm still waiting on a (hopefully buzz free) 151.
post #13 of 1627
6/30/08 at 1:08am
- DTV TiVo Dealer
- offline
post #14 of 1627
6/30/08 at 5:38am
post #15 of 1627
6/30/08 at 5:44am
post #16 of 1627
6/30/08 at 6:36am
- chadmak09
- offline
I think the buzz has alot to do with the position you sit from the TV like robert said.
If you sit directly in front of the set between 4-16 feet, you can hear it a whole lot more than if you sit to the side.
You have to be in "the path of the buzz" so to speak.
My living room is small and I sit directly in front of the panel (I would sit nowhere else).
If you have a large living room then you may not have an issue with the buzz.
I have my 6020 kind of in a corner also, maybe that is part of the reason
The thing that baffels me is that my 5080 did not buzz like this at all. At all.
I had to stick my head behind the TV to hear it, or stick my head one inch from the screen and listen extremly hard just to hear a peep.
So whats the big difference. The 6020 is 60 inches and has many more pixels but I still have a hard time believing that those differences would make the buzzing so much worse. Maybe some difference but not "night and day" like I have noticed.
And every person that has come to my house has noticed the buzz.
If they are standing to the side of the TV they will not hear it.
Its when they sit in my recliner (directly 9 feet in front of the TV) that they hear it.
And everyone from my 28 year old brother to my 61 year old mother (who has had Ear surgery due to infections on both ears) notices the buzz when sitting in the recliner. So who knows.
But Robert is right, when watching regular TV the buzz is not an issue. The sound drowns it out. And in a slient scene its not bad unless you really listen for it and there is a "Bright" image on the screen. During dark silent scenes I have a hard time even hearing it.
Normal viewing is not an issue for me at all now. And when I surf the net its "powersave mode2" time!
Its alot better when you can do something about the issue.
I would be willing to bet that if someone snuck into my settings and changed it to powersave mode2, I would not be able to tell the difference unless they told me.
The brightness decreases that little. So for most people I would recommend powersave mode2 and forget about the buzz and enjoy your new Kuro.
post #17 of 1627
6/30/08 at 6:46am
post #18 of 1627
6/30/08 at 6:50am
Hope this helps.
-Robert
Hope this helps.
-Robert
Good post Robert but I have to disagree on a few points based on my and other customers experience.
Individual hearing plays a big part what I can hear family members have not been able too.
No surprise luckly I can still hear the higher frequencies in my late 40's or is it lucky?
My 150 was fine till about 130 hours then it developed the cyclical buzz that fluctuates higher on light scenes and lower on dark scenes. This fluctuation is what makes it extremely noticeable.
Brougt it stores attention and tried special power cable, Tripp Lite power conditioner, and power supply replaced as well with no success. Pioneer varified it was the panel and it would have to be replaced. Seveal customers who had the same issue had their sets replaced and the buzz was not there! So not all the panels have the issue! On that note why would my set that had the standard and normal behind the panel buzz that could not be heard during normal viewing develope this issue after 130 hours? I am located at sea level on the East coast so it is altitude causing the problem in our area.
My question still is what is different between the sets. Same location, same person. Could it be how certain components are tightend or dampinning materials are applied during manufacture? Are there Varences in panel assembly or locations?
Now my PQ is outstanding but when I watch and have the buzzing going up and down it is detracts from my viewing. Turn volume up the over power the buzz works until there is a quiet scene.
Also I can hear the buzzing even if I am off axis. I am sitting about 12 feet away and the panel is on a stand.
post #19 of 1627
6/30/08 at 7:14am
I agree that the panel buzz is variable. I think if you can hear it with TV volume set to about 10-15 sitting about 10 feet away, it is abnormal.
In my case, the buzzing appeared, was quite bad, then slowly over several hours and days of viewing, it decreased to a much less notable level. I think this happens to be a common defect that is difficult to quantify, unlike a dead pixel or other defects. Since it is difficult to objectively measure the intensity of buzzing, many people are left to wonder if perhaps they are just being too anal.
I think I have a guess to determine which panels are defective in buzzing. If powermode save 2 significantly reduces buzz volume (from very loud to hardly there), then it is defective, if it reduces buzz but not by much, then this is the normal amount of buzzing.
post #20 of 1627
6/30/08 at 8:43am
- optivity
- P6 HMC/VIOS/AIX 5L
- offline
- 10,907 Posts. Joined 9/2004
post #21 of 1627
6/30/08 at 9:34am
Originally Posted by E-A-G-L-E-S
Hmmm......drfoo has no posts on avs forum other than his vote that the buzz caused him to return his 9g??
Also, sanhacker has been in the 9g thread talking about a '20' series with a blu-ray or a sig. series, so I could be wrong but I'm not sure he has owned a 9g yet.
I apologize if my lack of posts caused concern as to whether or not I actually own a 9g. I have been following the 9g forums for weeks and only registered recently in order to access the 6020 review by D-Nice. I have not posted as I felt the anything I have to say would simply be redundant with the current posts.
I recently finished an entertainment area in my basement and 2 weeks ago purchased a PRO151fd from my local BestBuy/Magnolia store. I do not live near a forum sponsor but Magnolia as well as several local small shops did match the great forum sponsor pricing plus tax. So I paid a 6% premium over sponsor pricing in order to get the 30 day return policy. I was very concerned (after reading all of the posts in the 9g forums) about buzz, dead pixels, etc so the 6% was, as one member stated, a worthwhile insurance cost.
It was delivered one week ago yesterday. To my dismay the set buzzed loud enough to be heard from 20 ft away and it changes pitch and level based on the display content. The Powersave 2 setting reduces the buzz to a level that I would guess is more consistent with what is being described as inherent to the display technology. There is a VERY subtle "hum" audible with my ear close to the front of the panel. There is a more pronounced "buzz" that changes pitch and level (based on content) emitted from the rear of the panel. It is fairly low frequency and only audible if you listen for it.
With the Power Save set to off (or 1), the culprit for returning the set rears its head. It is much higher pitch and much higher in level. It is fairly directional as others have stated and loud enough to be distracting in quiet scenes. On Wednesday a new PRO-151fd will be delivered as a replacement. I will test the new unit side-by-side with the current unit and report back with the results. The current set appears to be pixel perfect and the (as all report) the picture is astounding.
Please feel free to PM me.
post #22 of 1627
6/30/08 at 9:37am
- optivity
- offline
What is the elevation above sea level of your residence?
Do not be troubled by your number of posts, because we all fancy ourselves to be "rocket scientists" in this Forum.
post #23 of 1627
6/30/08 at 9:48am
post #24 of 1627
6/30/08 at 9:57am
I don't know why anyone would care who bashes any brand, if you're happy with your tv does it matter what anyone thinks? Alot of people like to bash Vizio also, LOL.
post #25 of 1627
6/30/08 at 10:15am
My 5020 buzzes. It is easily noticable from the back of the set. Only seems to be noticeable from the front if you are very close to the screen.
I didnt recognize it as the "directional" buzz as some had described it in the 8G thread.
So far it does not bother me at all because it is not noticeable with the volume on at any reasonable level.
post #26 of 1627
6/30/08 at 10:17am
Because if this poll can remain somewhat accurate it allows for Pionner to be made aware of shortcomings in order to produce an even better panel the next generation.
At least, that's why I would like it to stay close to accurate.
post #27 of 1627
6/30/08 at 10:26am
Yes, but it goes both way's, i'm sure people post NO buzz too that might not be truthful, how do we really know?
post #28 of 1627
6/30/08 at 10:28am
post #29 of 1627
6/30/08 at 10:29am
- optivity
- offline
post #30 of 1627
6/30/08 at 10:32am
I live about an hour north of Atlanta, GA.
It might be interesting to have an additional poll for "Does Power Save 2 significantly change the buzz?". For my set it is night and day.
I wish that I had a microphone and an oscilloscope with a Fourier Transform so that I could characterize the frequency content under the different power save settings. I may be kidding myself, but it seems that when I turn off power save 2, I hear the louder, higher pitched, and more annoying sound in addition to the less annoying sound when power save 2 was engaged. By monitoring my voltage stabilizer I do see the current draw of the set drop significantly when Power Save 2 is engaged. I find it surprising since the picture change is minor relative to the percent change in current.
- Pioneer 9G "buzz" poll (Elite and non-Elite)
AVS Top Picks
Currently, there are 1081 Active Users
(136 Members and 945 Guests)
Recent Discussions
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 11 seconds ago
- › Sony 46" WEGA 3LCD Lamp Issue (KDF-46E2000) 25 seconds ago
- › ZT60 Series, Shipping May 2013, Models/Sizes/List Prices 1 minute ago
- › Sony STR-DN1040 Vs Denon AVR-X4000 4 minutes ago
- › OLED TVs: Technology Advancements Thread 4 minutes ago
- › Star Ceilings... Painted or Fiber optics? 5 minutes ago
- › Knoxville, TN - HDTV 6 minutes ago
- › Seven Years ago HD DVD Landed.... 7 minutes ago
- › Official OPPO BDP-103 Owner's Thread 9 minutes ago
- › Low Vocals and Center Speaker Solution Suggestions 10 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
