Pretty sure this is caused by the break-in period unnaturally stressing the fans/circuits for an extended period of time. After running the set for a couple days there was some buzz on the set when I woke up this morning. Turned it off and turned it back on and it was gone. Leaving it off for right now to let it rest but will check back later to see if the buzz is still there.
This pretty much confirms for me what others have said, that it's unwise to run these sets for extended periods of time, namely longer than they were manufactured to be run, straight. I'm hoping that was just temporary since I haven't done the full break-in period. I'll finish the break in period, but I think a lot more carefully now.
A lot of people seem to think that nonstop breakin is harmless, but it most definitely stresses these sets more than they were designed for. You don't run a new car to 200mph the first day you have it just to see if it can and you shouldn't run these sets at max settings, max strain for 150 hours straight with no extended rest periods (like you'd have under normal viewing). At least that's my take based on observing my set (which I assume is fairly similar to most of them).
Can't wait to get rid of it.
That was the loudest sound in the room. My phone is totally oblivious to it (I've cranked my speakers as far as they would go). How can I make my hearing the same as the phones
I'll get a pc mic and record on the pc tomorrow.
Seriously, that's the dilemma that so many here have faced over the past 15-16 months: it's virtually impossible to know whether your own panel buzz is within a normal range or whether it's excessive. And you don't want to settle for one of the outliers.
