AVS › AVS Forum › Video Components › Home Theater Computers › Avr that works with Htpc, sound and video over hdmi
post #1 of 6
After the pita with the Yamaha rx-v663, Hdmi treated as Dvi from Asus M2A-VM HDMI/Gigabyte GA-MA78GM-S2H mb described in this tread http://www.avsforum.com/avs-vb/showthread.php?t=1033533
I´m lost, any possibility that you can post your working Avr/htpc sound and video over hdmi combination, It would make me really happy
Göran
post #2 of 6
for budget Onkyo 606 is hard to beat.
I own a Onkyo 885 pro pre-amp and I like it a lot!
http://www.onkyousa.com/prod_class.cfm?class=Receiver
post #3 of 6
The problem here is the ATI video/audio. It just doesn't work with the Yamaha. Though Intel and Nvidia do work with the Yamaha.
I have also heard of issues with the Onkyo 606 and ATI but those are resolved I believe.
post #4 of 6
This is a helpful thread, so thanks to the OP. I know there was an issue with the Denon 2308, 3803 and the 780G chipset. Has that been resolved? Seems like the Onkyo 705 works okay, can anyone confirm?
I can't decide if I want to wait for one of Denon's upcoming models or not.
post #5 of 6
I'm using a Denon AVR-788 with an ATI HD3450 without major issues... The only problem I have right now is that sometime, when I turn on the AVR and TV I don't have any sound and sometimes the resolution falls back to 640x480 16bits. But since I upgrade the HDMI audio drivers with the ones on Realtek web site I didn't get any of these issues... I'm also running MediaPortal under Vista 32bits.
Ati Catalyst Drivers 8.4
post #6 of 6
I´ll take a look at the Onkyo, hopefully their will be some more working combinations presented
