AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Channel Master CM-7000 channel banner sticky
post #1 of 10
My channel master CM-7000 has what appears to be a firmware bug that causes the channel banner to stay on the screen forever. Normally, after changing channels, this "short form" banner shows up and times out. However, after changing channels a bunch I find that occasionally it just stays on the screen until I eventually push the Info button to bring up the information (long form) banner and press again to dismiss it. When I do that, something buggy must be going on because when the information banner appears the video goes black (not the normal behavior). Then when I press the info button again, to dismiss it, the video comes back and the box behaves normally again.
Have any of you seen this sticky channel banner behavior?
post #2 of 10
Yes, I have a similar problem. But no blackout, just a sticky banner sometimes, cured with the info button.
post #3 of 10
Same thing here, no blackout but occasionally need to push info to clear banner.
My Sony CRT does the same thing so I'm used to it. Now I've got 2 devices I have to worry about the banner not going away Gotta love it
post #4 of 10
I've had that same problem too at times...
Bob Diaz
post #5 of 10
I don't have an answer for why its happening, but I find the sticky banner occurs when changing channels in succession within two or three seconds. I found that if the up/down channel buttons on the remote are quickly pressed and then released (just enough to change channel) ,it happens less ,then if the buttons are held down longer.
post #6 of 10
Hi there
You've written a good problem report. But there's no reason to start guessing the cause, i.e. a "firmware bug". You're encountering a problem, a bug. For all you know, it could be a hardware bug. (Yes, I'm a FW engineer, and I hate to read bug reports that guess at the cause instead of just reporting symptoms, effective workarounds and other observations.)
Regards
post #7 of 10
OK then, how about a broadcaster induced, HDTV format related, HDMI 1.3, low-VHF antenna interference, signal strength related, too-small wire guage induced, foreign manufacturing quality, marketing problem? Let me know if I've missed the opportunity to offend everyone equally.
Originally Posted by blue_z View Post
Hi there
Regards
post #8 of 10
Hi there
Regards
FWIW (as a former software developer and tech writer), IMO it *is* a "software bug" for the software (including firmware, which is just software "carved in stone") to not trap/deal with hardware issues. (I don't limit this philosophy to hardware issues -- I extend it to all venues, most particularly *user* "issues" -- i.e., the software should be sufficiently bulletproof to ensure that inadventent keystrokes won't crash it.)
As to the case at hand, the classic example is the old TRS-80 kkey bbounce problem (eventually fixed by an OS upgrade (and with later models, I presume a firmware patch), initially addressed by a small driver loaded via cassette tape). It drove pretty much all users batty until they finally came out with the tiny pile of code to filter out the keybounces -- which *should* have been included in the firmware.
Yes, it was a "hardware problem" but it was equally a firmware problem (no way were they going to reengineer the entire machine to use bounceless keyswitches -- if such a thing existed; the firmware author(s) were presented with a machine that needed bootstrap/BIOS firmware, including a keyboard driver (the keyboard was scanned/mapped from the main address space -- a keyboard driver was integral to the system, and probably a bit of a PITA to code; including a debounce routine that would be evoked in the middle of what had to be an ugly kludge of an address scanner, in a non-multitasking environment, on a 1.77 MHz 8 bit computer... glad it wasn't me! )
Anyway, having hardware that includes misfeatures that are NOT compensated for by the firmware... is a firmware bug, IMO. The firmware developer(s) are hired to come up with code to turn the hardware into a usable product. Hardware always has "issues" and the software is the last line of defense, standing between the user and the iron.
Edited to add that I had NO connection with the TRS-80, other than as a *very* early adopter some thirty odd years ago. I don't want anyone to think I was involved with that project, since I wasn't!
post #9 of 10
Agreed. The software (firmware) turns off the banner base on a timer. If the hw timer failed, a lot of things will fail. So 99.99% firmware bug.
The timer bug is actually very severe for people who plan on controlling the CM-7000 with TiVo, since TiVo has no idea its banner is stuck. Let's hope the issue is only related to Ch+/Ch-.
post #10 of 10
Please discuss this in the main CM 7000 topic.
This thread is locked
