AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › The Official Panasonic DMP-BD50 Owner's Thread
The Official Panasonic DMP-BD50 Owner's Thread - Page 2
post #31 of 1284
Originally Posted by JonStatt View Post
I want to echo another poster above that the analogue outputs seem to be very good on the BD50.
I have also compared DD/DTS via SPDIF vs 5.1 analogue outputs lossless. With A/B switching after normalising the volume levels, there is a significant and obvious difference.
I would love to know what DACs are being used. I also have a Sony S500 which has Burr Browns with similar performance to the S1. With that player the difference between analogue outputs and DD/DTS via SPDIF were not as significant. So now I am really curious what is in the Panasonic...but I am not brave enough to open mine up to find out.
The Lexicon MC-12 fortunately allows bass management, room EQ and time delays via its analogue inputs, albeit at the expense of an additional ADC process (near transparent though). But nevertheless I am comparing DD optimally connected via a digital link, vs lossless by a questionable link (the 5.1 analogues). The fact the difference is still so prevalent particularly in dynamics and fullness (e.g. opposite of thin sounding), is a testament to the quality of components used in the panasonic.
I must say, I am pleasantly surprised.
Jonathan
BD30 uses a PCM1680. (burr brown)
I suspect the 50 uses the same digital board with extra chips for the network connector and functions. (Unused connector and chip locations are on the BD30 mainboard)
Can be more sure when someone opens up the 50 and posts a picture.
Be brave, nothing can happen if you remove the cover.
post #32 of 1284
Jonathan
Unless I am misunderstanding, you are comparing lossy tracks through SPDIF against lossless tracks through the analog outs. That's about as fair as bringing a gun to a knife fight.
post #33 of 1284
has anyone managed to get BD live to work with the BD50? all my internet settings are correct, the test on the BD50 is even positive, yet BD live doesn't work, neither with "rambo", nor with "men in black"
post #34 of 1284
You are not misunderstanding, but I do think you are missing my point.
Firstly by comparing SPDIF against the analogue outputs, we can verify that the BD50 is absolutely and definitely outputting lossless through its analogue outputs. I am sure you have seen lots of discussion where people are questioning if their blu-ray is decoding lossless through the analogues, because they can't hear the expected large difference.
Secondly, the DACs can be a letdown and the gains of lossless can be lost. As I mentioned in my post, the Sony S500 had far less distinction between lossless analogues vs lossy SPDIF. THis indicates the BD50 is doing a better job.
post #35 of 1284
Well that is strange if that turns out to be the case.
The PCM1680 is a monolith 8 channel DAC. It has an SNR of 105dB
The BDP-S500 I believe uses 3 PCM1791 DACs. It has an SNR of 115dB.
A single 1791 costs more than a 1680.
Other statistics also fall in favour of the S500, yet that is not what I am hearing.....
EDIT: Panasonic quote the SNR as 115dB for both the BD30 and BD50.....which seems to contradict the DAC specifications
post #36 of 1284
may I ask which settings you use?
as far as I understand, you can chose 2 settings:
1) bitstream
2) PCM
1) sends the new formats via bitstream to the receiver over HDMI. over SPDIF you get the dolby or DTS core track.
2) PCM - the player internally decodes the losless tracks in PCM and sends it as PCM via HDMI to the receiver. over SPDIF you only get PCM 2.0 with this option.
what I now would like to know - which sound does one get over the 5.1 analogue output in cases of 1) and 2)? by chosing 1), the player outputs trueHD als trueHD and DTS-MA as DTS-MA. however - does it really decode trueHD as trueHD for the analogue outputs or does the BD50 use the core track, when chosing "bitstream"?
post #37 of 1284
Fair enough. DAC's can and do make a difference. I might be spoiled but I still find it hard to believe that certain equipment can make almost no distinction b/w lossless over analog and lossy over SPDIF.
post #38 of 1284
1) bitstream
2) PCM
Building on stefanpaulmayer's question, it seems like there may be a possibility your comparisons on the Sony may not have been entirely fair. If you listen to PCM 2.0 channel over SPDIF and compare that against the lossless over analogs, then you are correct in saying there's not much difference since both are effectively lossless. However, if in fact you are bitstreaming the lossy over SPDIF, then you are comparing correctly unless you were not outputting lossless over analogs to begin with.
post #39 of 1284
1) bitstream
2) PCM
I am not infront of the BD50 at the moment but I recall the setting that makes that difference is "Secondary Audio". When Secondary Audio is on it locks everything to PCM and you only get 2 channel out of the SPDIF. when you turn Secondary Audio off, it sets everything to bitstream and you get proper DD or DTS via SPDIF. But in either case, from the testing I have done, you still get lossless audio out of the analogue outputs.
I seem to recall a third option for Secondary Audio where you can choose PCM or Bitstream for each format...and then it outputs DD even for a lossless DTS track...I guess it is actually transcoding/re-encoding to do that.
post #40 of 1284
that's interesting. I have to re-check. however, you can definetely also set dolby/trueHD/DTS/DTS-HD to PCM over the menu. what I did a couple of days ago was an A/B comparision of the 5.1 analogue outputs with the SPDIF output of my HD DVD-player HD-EP10. as software I used the DTS demo and dolby demo blu-rays and HD DVDs (I have both in both versions), so I had absolutely identical source material - and the HD-EP10 sounded better, although trueHD and DTS-HD were only output in their core version over the EP10. that made my believe that the BD50 does not output losless over its 5.1 analogue outputs
post #41 of 1284
Keep in mind that we probably don't have solid confirmation yet as to whether or not the BD50 has the "5dB low LFE" bug either when decoding the lossless tracks for the analog outputs or when decoding the lossless tracks for HDMI LPCM output.
This too could make the "decoded for analog" audio sound worse even though decoding of the lossless track is actually happening.
--Bob
post #42 of 1284
I do not believe this is correct. I have Secondary Audio On and when I switch to SPDIF I get 5.1 DD or DTS out of all speakers.
post #43 of 1284
--Bob
I don't believe so, because I used HD Basics Blu-ray and measured the test tones and the LFE was at the same level as the main channels over analogues.
post #44 of 1284
I was definitely only getting stereo orginally out of the SPDIF and I fiddled with the secondary audio setting to get DD and DTS. If I have recalled the setting/terminology wrong, I apologise. WHatever the case, the default when I first got the unit only output stereo and I had to make setting changes.
post #45 of 1284
Hmm. I don't believe it possible that any player will decode two formats at the same time.
So if you set the TrueHD/DTS-HD to PCM, are you saying that it is decoding this lossless format internally to PCM....and then also at the same time decoding the lossy core/parallel track and piping it out of the analogues. That really would be a strange thing to do as that would be extra processing overhead and unneccessary. Remember that when you are decoding the lossless to PCM, but still passing the lossy out of the SPDIF, it is not decoding the lossy, it is purely passing the read bitstream out. This excludes any special provision for secondary audio.
EDIT: Just to add, in the case of DTS-HD MA there is a lossy core. In the case of TrueHD, there is not a core. It is a separate parallel track.
post #46 of 1284
I have now set the BD50 to bitstream. I than did an A/B comparision over the 5.1 analogue output and digital optical. the 5.1 analogue sounded much better with "MIB", with "Rambo" the difference was not that obvious
I than again did the comparision with the HD DVD and the dolby demo HD DVD and blu-ray. this time, the HD DVD-player didn't sound that much better. however, the BD50 didn't sound much better either, although it should because it has trueHD decoders...
post #47 of 1284
Doesn't your HD DVD player have a TrueHD decoder as well? I thought that was part of the bare minimum decoding spec that all HD DVD players had.
post #48 of 1284
yes, but it is not possible to output trueHD over SPIF, therefore normal dolby digital is output via SPDIF and optical out. and therefore, it is very interesting that the BD50 doesn't sound significantly better over its 5.1 output
post #49 of 1284
To validate that the BD50 is really playing the right track on your test Dolby/DTS blu-ray, press the audio button and confirm what it says on-screen.
One slightl point is that the parallel DD track on Blu-rays is 480kbps. The HD DVD player transcodes the TrueHD to 640kbps DD. This will make the difference less, but it is strange that you hear no improvement on the analogue 5.1 outputs.
What receiver are you using? How are you managing bass and distance management with the analogue inputs? If you are not getting proper bass and distance management via the analogue inputs, this can seriously affect the things. Does your receiver provide EQ capabilities...perhaps it applies those via SPDIF but not analogues.
post #50 of 1284
Just my 2 cents worth here...My understanding is that HDMI audio must be set to "OFF" to enable 5.1 lossless over analogue.
post #51 of 1284
Originally Posted by dloose View Post
I'll just throw in my 2 cents worth. I had a preorder in for the BD-50 in January! and waited patiently for months. Finally said the heck with it and bought a 40g PS3 for $300 at Wally's. Could not be happier. It is a fine BD player, no glitches I've seen with ~ 20 BDs...
Let's not turn this into another "the PS3 is better and cheaper than all Blu-ray players" thread! Let the owners talk about their exciting new player in this BD50 Owners Thread.
Please keep all the PS3 and other player talk in the below thread where it belongs:
http://www.avsforum.com/avs-vb/showthread.php?t=969206
The official "Help a Guy Pick a Blu-ray Player" thread
post #52 of 1284
Wouldn't the BD50 output Dobly Digital Plus through SPDIF? And therefore you wouldn't notice as much difference over the 5.1 analogs? Not sure.
post #53 of 1284
Are you sure about that? Everything I have read indicates the companion DD tracks on Blu-ray are generally done at 640kbps since BD is not limited by the DVD specs.
S/PDIF won't do any of the advanced codecs. Legacy DD and DTS are the limit.
post #54 of 1284
Would someone be kind enough to test the load times on the BD50 like with POTC 1?
1. From tray closed to previews
2. From end of previews till movie is ready
3. also the BD50s boot up time from power ON
That would be great. I think a lot of people will want to know this.
post #55 of 1284
You need to remember that the LFE bug only affected HDMI audio, levels are fine for 5.1 output (BD30) or 7.1 outputs (BD10/A). Over analog out you will have proper levels even if the LFE is -5db on HDMI audio output.
post #56 of 1284
This is correct. I have never had a problem with LFE on my 10AK. Bass is excellent as it is on the BD50 as well, through the analog outputs. I do not use HDMI for audio. Panasonic has done an excellent job on the analogue outs on both units, although dropping 7.1 on the BD 50 is a bit of a disappointment.
post #57 of 1284
Could you please confirm that the BD50 sounds much better over analogue than the BD30 since the BD30 does not decode.
post #58 of 1284
I am a proud owner of a US BD50 as of yesterday. So far I am very pleased with the performance of the player but have notice one rather strange problem with Signs and The Lion The Witch and the Wardrobe, so I am guessing it may affect all Buena Vista BDs with BD Java.
What happens is that when the disc loads and the trailers start to play if you press top menu on the remote the disc stops rather than take you to the disc menu. The work around is that you can just manually skip through the trailers but its a bit annoying. Anyone else experienced this?
post #59 of 1284
I can't comment on the BD30 as I do not have access to one. The performance of the BD50 is the same as the 10AK via analogue with the exception that it is only 5.1 not 7.1 and will the addition of DTS HD MA.
post #60 of 1284
How are you "first users" finding the SD DVD playback display quality to be?
