AVS › AVS Forum › Display Devices › CRT Projectors › Strange line on Marquee 8500 screen
post #1 of 7
One strange line appears on all three screen with no input signal or when the background is dark especially with film credits. With internally generated diagrams, seems to be fine. It gets more noticeable with increase in brightness control.
post #2 of 7
On Curts site, go to advanced procedures ->marquee -> downloads->:TB94-08: Bright Vertical Line on Right Edge Of Image .
post #3 of 7
there's another TSB to get rid of that annoying dot in the bottom left too Keep in mind that both of these are what I consider advanced soldering jobs, not a good place to learn IMO.
post #4 of 7
I am connection with the Bio-engineering dept., so i think I am safe. What are the other links? Thanks in advance!
Alex
post #5 of 7
Just check the line is similar and is on the right side, but when I was doing the blanking the line did not move. I guess is not the same problem, thanks for trying!
Alex
post #6 of 7
Originally Posted by richmond5 View Post
I am connection with the Bio-engineering dept., so i think I am safe. Alex
bio engineering students + electronics soldering = disaster
hopefully you have a professional technician working for the department to do this?
post #7 of 7
One more pic. from the blue tube
  Back to Forum: CRT Projectors
