Originally Posted by
JJ7
Is it possible to easily setup the S350 to just pass 480p when playing DVDs? I'd like to try using my receiver (which has Faroudja/DCDi) to do the upconversion to 1080p. Of course when playing blu-rays I want 1080p(/24) output. In reading the manual I didn't see an obvious way to accomplish this.
Also keep in mind the 'forte' of the Faroudja chipset is
de-interlacing, not necessarily
scaling. By feeding a 480p signal from the S350 you are effectively only using the receiver to
scale, and it is very likely that the TV or S350 will offer improved scaling. You will need to set the S350 to output 480i (DVD's are encoded 480i
not 480p) to compare results, and as mentioned above, this will need to be selected manually each time.
