Originally Posted by JBaumgart
Rich, thanks for trying to help me.
I've already tried to disconnect and reconnect the power, at both ends and directly into a wall socket, with no success. Nothing lights up, so I guess my player is "bricked" as they say. I looked at page 56 and there is nothing that seems to describe how to reset the player (which I would imagine it wouldn't do anyway if it does not have any power and won't even turn on).
Kind of ****es me off, because as I said this player has had VERY limited use, and I was just trying to keep its firmware current, even ordering the upgrade disk from Sony and closely following all directions. On my other BD player (Oppo) the firmware update worked flawlessly.
Is there any chance this was connected to power when you had a power surge and maybe it fried the power supply in the player? I've had that happen to some A/V equipment in the past - thankfully never a blu-ray player. If it was my player . . . this is the point where I would take it apart and look for a fried in-line fuse inside. If you find one, and it is blown, get a replacement (Radio Shack, probably) and try it. If the power supply in the player was cooked - the replacement fuse will blow also. Then it's a question if you want to pay to have the player fixed . . 99% probably not worth it. If you find yourself there - send me a message . . your player might be worth a few bucks for spare parts for my S350 and S550 players.
If you have Best Buy stores in your area - march into the Magnolia section and look for a Sony BDP-S1000ES. If you do not see one, ask for one (either new, or a top condition demo). They are on sale for $99.99 and top notch players - far superior to the S350 . . . Be sure to insist on the proper 106A model remote for it (to control the volume on the headphones output at least). If they are selling you a demo - try to get them to lower the price to at least $89.99 (they did that for me).
So i changed the setting to Video and low and behold no judder and a sharper/cleaner image
So i guess the correct Cinema conversion setting for film based material is Video from the 350........ I think the PS3 is the same and probably other Sony BD players ? On a side note i have'nt tried any Dvds as i only have BDs now anyway
