AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › The Official Sony BDP-S350 Owners Thread
The Official Sony BDP-S350 Owners Thread - Page 4
post #91 of 6745
Originally Posted by rveras View Post
Double check the following settings:
Audio Output Priority: HDMI
Audio HDMI: Auto
BD Audio Setting: Direct
Audio ATT: Off
Dolby Digital: Dolby Digital
DTS: DTS
Audio DRC: Standard
Ok, got it. ty
post #92 of 6745
Originally Posted by Brad1963 View Post
I spoke with ABT this afternoon, they are expecting their shipment probably Wednesday. They are getting 500 units of the SONY BDP S350 and have only 45 pre-orders to fill. The pre-orders will be filled and shipped immediately.
Interesting. When I pre-ordered mine a few days ago, Michael told me that they had about 70 pre-orders. My guess is that it has increased since then, but perhaps quite a few folks cancelled theirs. I think the total pre-order number is well within the 500 units that ABT is expecting from Sony.
post #93 of 6745
Audio HDMI: Auto
Audio ATT: Off
DTS: DTS
Audio DRC: Standard
+1
and you may also need to hit the straight button the front of the yamaha to turn the processing back on. Which I believe will turn the processing back on including the TrueHD decoder.
Randy
HTdreamming
post #94 of 6745
Originally Posted by jlangner View Post
As far as the Flash Memory. The slot is very small. I had a SamDisk 2GB flash drive so wanted to try it. No go, its too wide.
http://www.officemax.com/omax/catalo...i_sku=21250691
Uh oh! That's not good. Is Sony trying to force us to buy their USB drives?
Or, do you mean the USB slot on the back is deeper than normal and therefore the Sandisk need to be inserted into it more but can't?
post #95 of 6745
What does the use of a flash drive gain you (what's it for?)?
post #96 of 6745
480i over HDMI anyone?
post #97 of 6745
Its too wide to fit in the hole. The plastic case is.
post #98 of 6745
You might be able to get a cheap 1 foot USB extension cable to use to plug your stick in via. I have a 3 year old Sony RPTV that takes it's firmware updates with- my sticks were all too big (wide) but I had an extension cable and it worked just fine.
Just a thought...
post #99 of 6745
Originally Posted by Ruined View Post
Well, scratch this one and the BDP-S550 off my (already very short) list.
For me at least,
No Source Direct = No Reon/Realta/VP50/etc for 1080i Blu-ray and 480i DVD = NO SALE!
Thanks for the quick work in scanning the manual guys, this cements my decision for the Pioneer BDP-51FD based on my needs to use the Reon chip in my processor for maximum quality. The BDP-51FD has no competition in its pricerange for use with an external video processor IMO.
For someone who does not have a receiver or processor with something like Reon/Realta and have no intention of buying one, though, the S350 unit is obviously still a good deal.
Told you some months back that the Panasonic S350, uhh, I mean Sony S350 would not have direct out
post #100 of 6745
The BDP-S350 doesn't seem to like my Sharp XV-Z12000 DVI port. I have been using an HDMI to DVI adapter cable to plug my HD Cable box into the projector for years, but if I try the same thing with the Sony, the projector says "no digital signal" and the player grays out the HDMI selection in the setup menu. The only way I can see the menu is with the component cables. I went to Best Buy and plugged the player into one of their tvs via HDMI and it displayed immediately. The player manual says that the conversion cable should work if the DVI device (projector) is HDCP compliant. Sharp tech support had no info on whether the XV-Z12000 (mark1) is HDCP compliant through the DVI port. Anyone out there know the answer?
post #101 of 6745
it's been asked and I'm asking again, what is the power up time and how long does it take to load Ratatouille? thanks.
post #102 of 6745
Folks - If the video output is via the COMPONENT jacks, will the HDMI output full 7.1 lossless audio?
post #103 of 6745
I am planning to use the new Integra DTC-9.8 preamp to do all of my decoding. Since the Sony S350 outputs all formats over bitstream, will I be missing anything?
thanks.
post #104 of 6745
JSKMDWK ,
You will have no problems at all.
post #105 of 6745
jimbo88 ,
HDMI will give you 7.1 lossless audio. What's your set up.
post #106 of 6745
thanks.
Based on initial reports, you will not be able to fully utilize the Integra DTC-9.8's high quality Reon video processor for deinterlacing content such as 1080i/30fps Blu-ray discs - most concerts and nature documentaries on Blu-ray (for example Nine Inch Nails, Galapagos, Nature's Journey, etc) along with a few 1080i/24fps (Short Circuit, Beer League, etc) films. Instead, you will have to rely on the $399 BDP-S350's internal video processing chip to do the deinterlacing unless you want to be messing around in the S350 player's setup menu every time you switch between a movie and concert; for reference, note that Secrets of Home Theater and HiFi found that the $499 Panasonic BD30 bobs 1080i/30fps Blu-ray Discs to 1080p, losing much resolution in the process. There are other 3rd gen player options by different manufacturers which allow you to output the original resolution, be it progressive or interlaced, to external video processor chips such as the one in the DTC-9.8 for optimal video quality with both Blu-ray and DVD. It is a shame to see that video processor go to waste.
For audio, though, you will be mostly covered. You will be able to hear all sound lossless via bitstream. However, when you want to watch PiP commentaries or other extras that require subaudio, you will be required to enter the player's setup menu and toggle the subaudio on (disabling lossless DTS-HDMA in the process) in order to hear any audio at all from the commentary... And after done watching the commentary go back in tho the player's setup menu toggle it back off so you can get lossless quality again with DTS-HDMA. A standalone player with builtin DTS-HDMA decoding would allow you to leave the player in PCM mode and get lossless no matter what while also allowing for subaudio from PiP commentaries without issue, though you could still use bitstream mode if you chose as well.
If you can put up with the aforementioned potential quality loss with interlaced material and the setup menu hassles of subaudio, the BDP-S350 may be okay for you however.
post #107 of 6745
Originally Posted by jsil View Post
jimbo88 ,
I want to video output via component cables to my (older) Pioneer PDP-5030HD plasma (it doesn't have HDMI inputs) and audio output via HDMI to my Onkyo SR705.
Just want to make sure the S350 can be set to output video separately from the HDMI audio.
post #108 of 6745
Blah-Blah-Blah! I've read enough. The PS3 is still the best blu-ray player on the market.
post #109 of 6745
...not withstanding the fact that it plays SACD's over HDMI, I have had no problems at all with any of my BD's. Audio or video!
post #110 of 6745
No 480i over HDMI for DVD output to a scaler.
No bitstream of HD nextgen codecs for those who want to use their receiver/prepro for decoding.
No native IR support.
Can be loud (depending on your luck).
Big and can't be stacked.
Subjectively not the best looking piece of gear on the block.
Functionally more complex than it needs to be for Blu-ray playback due to obvious reasons.
In other words, its not even close to the best for many
post #111 of 6745
Does anyone know if the S550 will also NOT output at 'source direct'?
Please say it ain't so!!
post #112 of 6745
nobody powered their newly received unit yet? ::
post #113 of 6745
What's the boot time?
post #114 of 6745
Bullet 1: I have three 777ES changers running into my Integra DTC-9.8 from a Escient Manager-Not an issue.
Bullet 2: The LPCM works beautifully
Bullet 3: 25 bucks for the bluetooth remote? OK, so I have to use that one along with my Harmony One. Big deal! So what!
Bullet 4: You can't be serious.
Bullet 5: It sits nicely in my BDI stand, but they do make ears for the PS3.
Bullet 6: Again; You can't be serious.
Last but not least; Bullet 7: It is the simplest piece of gear I have ever owned. It also talks to my computer making it the cheapest server on the planet.
As a custom installer, our company doesn't sell them because there is no money to be made. I have 14 units of gear + amps, and the PS3 is everybody's [in my home] favorite unit. Thank goodness it doesn't bitstream the new CODEC's, because it would be in the same boat as the rest of the player's with the popping noises and handshake issues that have plagued us early adopters. When a stand-alone gets released that can beat this unit, I'll give it its due consideration, but for now the PS3 is hard to beat!
post #115 of 6745
You missed:
No multi-channel analog audio output for those that need that.
Incorrect Studio RGB output (no BTB or Peak White data) for folks who can't use YCbCr video output.
That said, if you have a receiver that accepts HDMI YCbCr video and high bandwidth, multi-channel LPCM audio and "does the right thing" with it (which means most current HDMI receivers), and don't mind buying an add-on device to enable use of common programmable remote controls, the quiet 40GB PS3 makes a pretty durned nifty and fast-performing profile 2.0 Blu-Ray player which has a proven track record of regular upgrades via software and ALREADY decodes all the lossless audio formats (no waiting for firmware still to come).
For folks in this very common situation, it is hard to see anything to recommend the summer crop of new, stand alone players.
And while you are watching a movie you don't even have to look at it....
--Bob
post #116 of 6745
Originally Posted by Bob Pariseau View Post
You missed:
--Bob
The 777ES changers have analog outputs IF I had needed them, but with a newer pre-pro (DTC-9.8) it's not a issue. If Sony, or anyone else for that matter, had put ALL of the features audiophiles want in these players, the unit would have cost 5K.
post #117 of 6745
Looks like Pioneer didn't build the Sony standalones this year like gen1 & gen2
Highly, highly, highly unlikely the S550 would output when the S350 doesn't. The S550 is an S350 with onboard memory + more comprehensive audio decoding. It appears you will have to buy a BDP-51FD/BDP-05FD if you want a 3rd gen "Source Direct" player under $1000.
post #118 of 6745
jimbo88,
Needs help can the s350 output video from component and audio out from HDMI to his Onkyo 705.
post #119 of 6745
Here's what I don't understand. Why not get a good BD player for blu-ray and a good DVD player like the Oppo and cover all of the bases for less money? Why does everything have to be in one unit? I can name a thousand reasons for having more than one player in your rack and one big con for having just one (all-in-one) player.
post #120 of 6745
I have an HD DVD player that I can use for that. Heck you can buy a HD DVD player for $60.00 if you need 480i over HDMI.
