AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › I need help choosing a replacement subwoofer
post #1 of 3
I have an 8" energy s8.2 subwoofer in my room and the speaker in it broke so i was wondering if it would be better to replace the speaker or just buy a new sub altogether. If so what midgrade sub would be compatable with the amp currently in my box.
Thank you!
post #2 of 3
Upgrade!! You can get a very good 12" internet direct subwoofer. How much are you willing to spend with shipping included?
post #3 of 3
Budget? Room size (in cubic feet)? Volume you like to listen at? Apt or house? What are the dimensions of the box in question? You may be better off with a new sub. Were you happy with your current sub's output before the driver quit?
