AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Zinwell ZAT-970A?
Zinwell ZAT-970A? - Page 39
post #1141 of 1144
Originally Posted by ElCoyoteSurvives View Post
Nothing seems to work to fix the channel 3.1 sound problem. What's weird, is that this problem started about the same time as the iView problem, perhaps a bit earlier, but did not previously occur for the years I've had the Zinwell. And it doesn't happen to any other tuner I have, on the same antenna or a different one.
That would appear to point to some kind of weird interaction, via close proximity to each other or through the cables (I'm assuming the iView doesn't have an aux. IR transmitter). An experiment might be to try some other recorder one night and make sure the iView is unplugged.
Back to the iView remote, see if there's anything in the menu system for setting a different remote code. I've seen this on higher-end VCRs and HDD/DVDRs. I have one of each. Would like to do that to my Toshiba HDD&DVDR as I also have a Toshiba DVDR, but I like to power the HDD off (the pig's hard-drive and fan stay on in standby) which makes it lose remote memory. I also use two ChannelMaster converter boxes for these two recorders because of s-video so using them at the same time is fun (fortunately they're in different cabinets).
My Zinwell has the same problem you have due to my ChannelMasters so I put a piece of black electrical tape over the lens with a tiny hole over the power LED; that hole also allows me to use the remote on the Zinwell if I get real close. Mr.Z doesn't get used much anymore as it's for the VCR or if I want to timer record to the DVDR when I'm away.
post #1142 of 1144
I had a similar problem and was able to resolve it by doing a reset, running the channel scan with the antenna unplugged (this is the only way to get rid of all the previous info), then re-connecting the antenna and doing a complete re-scan again.
post #1143 of 1144
Ah, I see. Properly designed they shouldn't require that but...
I bet there's a more thorough reset as a switch on the circuit board, or more likely via factory software programming.
post #1144 of 1144
OK, I tried this. Unplug antenna. Load Factory Default. Select English and Central time zone. Channel scan started, found none. Power off. Plug in antenna. Power on. Select English and Central time zone. Channel scan started, found most of my channels.
Channel 3.1 has audio, and the audio has persisted for a couple of hours now. I think it is fixed. Thanks to you guys for looking at this and for your advice.
