Rgb standard is to be used. Enhanced is a different setting , that might be used with some projectors if i remember correctly, with different type of calibration on the pj though.
Deep colour does nothing since there is no such "signal" recorded in the bd disc.
I also have it set to auto , but it does nothing.
As for the rest above , you might want to ask a pro calibrator to recalibrate your kuro along with a1ud as player , to get the best out of your tv.
