When my RX-V2700 processes a Dolby Digital EX soundtrack, it appears to use the Dolby Pro Logic IIx decoder. It either does this automatically or manually.
Now, if the Dolby Digital EX soundtrack is sent through PCM, I would have to manually enable the Dolby Pro Logic IIx decoder. But there's no way for the receiver to know the soundtrack is Dolby Digital EX.
Does this make a difference? In other words, does the receiver tell the DPLIIx decoder when it's decoding an EX soundtrack? Or does DPLIIx not need to know this?
What I am curious about is whether there is a difference between bitstream DD EX being sent to the receiver vs. the DD EX soundtrack being sent via PCM. In the case of PCM I can turn on the DPLIIx decoder manually, but if it's dependent on knowing whether or not it's decoding DD EX, it won't know that fact when decoding from PCM (as from a PS3)
I guess my confusion results from not understanding how DPLIIx works. I know it can create a 7.1 soundfield from a 2 channel or 5.1 channel soundtrack that lacks any matrixed sound information. But it also seems to encompass the ability to decode a DD EX soundtrack. Is it because the method used to decode the EX soundtrack is identical to it's ability to take a standard 5.1 DD soundtrack and create extra channels for it?
