In addition to the apparent lack of available spectrum in many areas for WSD operation per the rules ... I wonder what happens if say, someone purchases a personal/portable WSD and uses it somewhere in Mid-america, and then moves to say, the Detroit area, to a (work or home) location within 32km of the Canadian border where the WSD operation won't be allowed on *any* channel ??? Assuming the WSD as required actually "stops functioning" when it is moved to this new location, Will the manufactuer of the device provide the consumer a full refund
To be honest, I personally think there are so many things wrong with this R&O and the rules adopted, as well as, fundamentally, the decision to allow WSD's in the Broadcast bands that I don't even know where to start ...
In summary, I think it's a mess, and I wouldn't be surprised if we don't soon see some modifications to the rules as currently adopted, although I doubt any such modifications will actually make this mess "better" .. ... if I were to sum up a response to it into one word, the one word that comes to mind at present is :
NUTS!
Here are a few additional general thoughts, though :
With the apparently limited resources FCC has(it seems they already have more than enough to deal with), I Really can't imagine how FCC is going to be able to properly implement and enforce many of the rules they've adopted ...
Also, given what has occured in the past with various unlicesned services (CB'er's running 2KW or not more/etc - how many of those guys "got caught"?), I would be very surprised if we don't see hacked, and/or grey market/non-compliant WSD's relatively soon .... Then there's the Geolocation database and concerns about potential accuracy and maintenance issues ...
Also there is the question of how harmful interference is going to be detected and identified ... I suspect in many cases, the only folks who are going to potentially know harmful interference to their (protected by the rules/within service area) OTA reception is being created *ARE* individual OTA users --- I say "potentially", because in the vast majority of cases, OTA DTV users are not going to have the equipment necessary to diagnose and identify the cause of interference .... Suspect in most cases, they will have *no idea* what is causing their poor reception or dropouts ... could be WSD's, could be Multipath/etc/etc ....
Originally Posted by
Sammer
Did I read that right, channels 3, 4, and 37 are excluded for use by TVBDs?
Yep. And as you noted in your most recent post, 2 additional channels will be excluded for wireless microphone use (1 somewhere between 21~36, one somewhere between 38~51) in areas near 13 of the Metro areas using Land Mobile. And, as you also noted, all channels are excluded for use by TVBD's within certian distances of Mexican and Canadian Borders(the area involved - within 32km of Canadian border would include much of the Detroit area for example), and within 2.4km of certain sites used for Radio Astronomy ....
Falcon77
Please let me know if the following is not correct.
Fixed Devices: 2, 5-13, 14-20 (outside of LM areas), 21-36 & 38-51
4W maximum EIRP
Personal/portable (mobile): 21-36 & 38-51
100mW maximum EIRP/40mW maximum EIRP on adjacent channel
That's how I understand it as well, as is specified in Appendix B, CFR 47, Section 15.107, 15.709 and Paragraph 105 of the text regarding explanation of the 4 W EIRP Max for Fixed devices and taking antenna gain into account ....
I am still uncertain if fixed WSD's will be allowed to operate on channels adjacent to LM (21 locally).
Follows is what it says in appendix B, for 15.712(d), regarding protection of LM (PLMRS/CMRS) operations and regarding co and adjacent(N +/- 1) channel TVBD operations -- In other words, this seems to say 1st adjacent channel WSD's aren't allowed within 131km of the LM operations of the metro areas listed in CFR 47, Sec 90.303(a), and within 51km of LM operations outside of those metro areas not specified in sec. 90.303(a) -- well, actually, specifically they are specified in 90.303(b) .... :
FCC WSD rules
"(d) PLMRS/CMRS operations: TVBDs may not operate at distances less than 134 km for co-channel operations and 131 km for adjacent channel operations from the coordinates of the metropolitan areas and on the channels listed in Section 90.303(a) of this chapter. For PLMRS/CMRS operations outside of the metropolitan areas listed in Section 90.303(a) of this chapter, co-channel and adjacent channel TVBDs may not operate closer than 54 km and 51 km, respectively from a base station.
CFR 47, Sec 90.303 is available here (currently - note the link for the "current" rule will change to having a "2009" in it in 2009/etc ...) :
http://www.hallikainen.com/FccRules/2008/90/303/
LA is shown as one of those 13 metro areas, using 470–476, 482–488, 506–512 (MHZ), or channels 14,16 and 20 ...
So, it would seem WSDs would not be allowed on channel 21 within 131km of the "Urbanized area geographic center" shown in 90.303(a+b) for LA area ...
45 appears to be available for fixed and mobile reception, by rule at my location, but I doubt it would be acceptable due to interference from KLAU-LP.
Also, Do be sure to note, as I posted earlier as detailed from the rules(sec 15.712 (a)(1) and R&O -- LP stations will be protected from interference from WSD's using the same threshold for service as used for full service TV stations, which or course involves a larger(in some cases significantly larger depending upon the stations faciltiies/etc) area than LP stations service (noise-limited) contours ...
For example, while a analog UHF LP stations noise-limited service contour is defined in FCC rules as being 74dBu contour, vs 64dBu contour for UHF full service analog stations .... For the WSD's, the LP's will be protected/WSD's won't be allowed to operate within their 64dBu contour, just like Full service stations ....
Also, note the required allowed seperation distances between (in this case for UHF) the 64dBu contour and a WSD for co or adjacent channel operation, with WSD outside of the stations coverage area is the same for LP analog or full service (see table in 15.712 (2) in appendix B or as I posted earlier) ....
