AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › PIXAR Screenplay slides for you all.
PIXAR Screenplay slides for you all. - Page 6
post #151 of 160
Originally Posted by Slitman View Post
just looking at setting up an HTPC with XBMC. can these be set up in XBMC to play before a movie starts ????
Yes they can, with a fantastic add-on called "Cinema Experience". LOVE that add-on, and it makes Movie Night much more fun.
post #152 of 160
thanks!
post #153 of 160
Thanks. Did you install on Eden 11 ? I can't seem to get it to work. I found and installed the add-on but cannot see the Cinema Experience tab/button (???) Am running Aeon MQ3 btw ...
cheers,
post #154 of 160
I think there is a different branch/version of Cinema Experience for Eden. I'm still on Dharma. It works for me and so I figure why change it?
Also, to access the Cinema Experience button, you need to first go into the movie info (by hitting "I" on the keyboard) and it should be an option there.
Here's the thread for Cinema Experience on the XBMC forum. Should have put it in my first post, but neglected to.
http://forum.xbmc.org/showthread.php?tid=87563
Hope this helps.
post #155 of 160
Thanks GJ! I got it working and first impressions are I'm loving it. Will fool around with it some more. Now all I need to do is find some trailers to add to my repository.
post #156 of 160
These are great? How did you do these? I would love to something similar
post #157 of 160
These are fantastic. I've never had a pre show before but always wanted something. These are the perfect slides and have inspired me to set one up.
I'll most likely be putting these to DVD and running them as a slideshow.
Can't say thanks enough for your generosity. I hope it comes back to you ten fold....
post #158 of 160
Just wanted to say I really REALLY appreciate all the work you've done to share these slides with us. MUCH thanks!
post #159 of 160
Wow very nice made slides!
Is there a way to adjust them (by myself) so i have dutch language?
post #160 of 160
Any chance you post the original PS files? so i can translate text to dutch please?
