Originally Posted by Splicer010
You ARE getting DD...just 2.0 not 5.1...Netflix for most only runs 2.0 while the newer 2011-up is 5.1. There is nothing wrong with your 789. Why don't you just use the MANY options the 789 has available like DD PLIIx? VERY difficult to tell the difference.
The reason you get 5.1 and TrueHD with blu-ray is because it is a different source, even though it is the same machine. The app for Netflix just doesn't allow for it likely in your player, which you failed to disclose what model/make it is.
For what it's worth, my BD player is a Samsung BD-C6500. Not sure if that makes a difference or not, but as BatPig mentioned, it still would not explain the lack of DD from my ATV2.
