Originally Posted by dogdoctor
Don't be sorry just read more. It is explicitly stated in the PS3 manuals/faqs online on how to get the HD audio codecs (then compare that information to what the Receiver manual says the device will do with that signal). In short: You can't bitstream via optical - bandwidth is not there. You must use analog outs (PS3 doesn't have) or HDMI (does have) but it doesn't bistream them here either. You must use LPCM/PCM which means the decoding was done at the level of the PS3. If the decoding is done at the level of the reciever, then you get all the pretty lights and names. If the decoding is done elsewhere (same signal mind you), then all you see is MultiCh In. You get the same great sound, no flashy lights.
I have the latest PS3 firmware and i have set my PS3 to Linear. I still don;t see MultiCH In anywhere on the display. The only thing i see on the display is DIG, HDMI auto, and AudysseyEQ. I even tried to set it to bitstream to let the reciever do the decoding and i saw nothing diffrerent!
What am i doing wrong?
, but whaddya all think?
