Originally Posted by ozcot
Bugs: What are your thoughts on the Audyssey Dynamic EQ ? I am interested in that cause I heard it is like The old Loud function on steroids. Want to have as much punch as possible but with clarity.. I was all set to get the 606 till the hum problem and heat issue were brought to my attention. I am now between the Denon 1909 or the older 988 which is now $650 from $1200 better sound processors and more power but lacks the Audyssey Dynamic EQ. Also looking at the Pioneer 1018 but it does not have any Audyssey technology it uses MACD for speaker set up not sure how it compares to Audyssey MultiEQ. Thanks for any info.
Audyssey Dynamic EQ is aimed primarily at correcting sound quality at lower volumes, see: http://www.audyssey.com/technology/dynamicEQ.html
Both the 606 and the 1909 have this feature and I found it to be very effective, compared to a much older system I had with a "Loud" function. I would give a nod to the 1909 over the 606 because, to my ears, the 1909 sounds a bit cleaner with Dynamic EQ applied. When I was looking for a replacement for the 606, I considered the 1018, but ultimately decided that I prefered Audyssey technology over MACD because it was developed independently of any AVR manufacturer and seemed to have broader support. Also, I decided that if I was going to change from the 606 (which I liked), I wanted an upgrade to an AVR with Dynamic EQ plus Dynamic Volume.
Whether Dymanic EQ and Dynamic Volume are valuable to you will depend on your listening habits. If you listen primarily at or above reference, you won't get much benefit from either. If you do a lot of listening at low to moderate volume levels, Dynamic EQ will provide a better sound quality. If you find that you are constantly lowering the volume during loud scenes, only to raise it to hear the dialog during quiet scenes, then you will really appreciate Dynamic Volume.
