If you choose a Denon dock, make sure to review the iPod dock Compatibility Chart to select the correct dock based on your requirements. Because the 1909 does not have a RS-232 jack, you would have to send it to an authorized repair facility to install the software fix for the video issue if using the ASD-11R.
The 1910 due out next month most likely will have the fix installed as well as including a new RS-232 jack.
Anyone have any other suggestions?
