Correct ... HDMI is passed through, while Component is upscaled. Although keep in mind that if you run 1080p (eg. Video on Demand) in via component, you must also go out component to the projector. It's certainly worth trying a component connection though, although as we've said many times here .... it's doubtful that the Denon will do a better job than either the Moto box or even what your Projector is already doing. The Faroudja video chip in the lower level Denon's is only a basic video chip which is why the newer 2010 models will have the ABT chip installed instead. Also, keep in mind that if you've got a 1080p projector, it already scales everything it receives to 1080p.
post #7561 of 11199
5/9/09 at 5:42am
. I fully discuss the "analog only" limitation of Zone 2 in my FAQ:
) as the only thing it will do is return all your settings to their factory default. A dialog normalization of -31db means the sound engineer turned OFF this feature on that particular disc. Sony is apparently doing this on their Dolby TrueHD BDs. AFAIK, when DN is turned OFF, it shouldn't reduce the audio at all, although I've personally never viewed a DVD/BD with DN turned OFF so do not have direct experience. Another option would be to select another English audio track if offered. What is the DVD title? Perhaps another owner can play it and provide us with the value their disc provides?
