Originally Posted by batpig
not necessarily, it's just a slightly different feature set. we still don't know if the 2 lbs that have been shed will actually translate into lower real power.
the new model adds a couple of cool new features (adjustable Dynamic EQ "strength" is important to me, since I have some "taming the bass" issues on some sources) plus the 4th HDMI input and new video scaler... but you may prefer the greater number of legacy inputs and heavier build of the older unit.
If you are happy with your current 1909/789 there really isn't that much of a compelling reason to upgrade though, nothing "earth shattering" in the new feature set. PLIIz sounds like a silly feature that is totally uninteresting to me.... I'll be more interested once Audyssey DSX (which looks to be far superior) trickles down.
True enough but one thing that I myself REALLY like is the channel(s) in and channel(s) out icons on the 789/1909...The 1910 they seem to have done away with these icons...Actually it is a different display all together it looks like from the pic on the website...The 789/1909 has a distinct advantage in that department...The omission of the XM antenna input (I know they merged but still) is another option dropped...The 1910 is deeper than the 789/1909 but it is also an inch shorter in height...The lesser conversion chip is a drawback and I couldn't agree more with the PLIIz crap...So what happens??? If you wish to have a 7.1 system in the traditional sense you cant if you use PLIIz??? And you also give up the possibility of using zone 2??? Talk about killing 2 birds with 1 stone...
The 4th HDMI would be nice to have for future use for me but at best the max i will ever need is 3 since I don't game...And should I decide to take up gaming I can always just use component (which BTW the 1910 has omitted 1 component input) for my HDTV OTA tuner which will free up another HDMI port...Should I ever go blu that will take the 3rd and final HDMI port...So as you can tell I'm good in the video side of the 789...
No problem with the bass feature...At least for me...TV is the only thing that seems bass heavy and that is only on 1 channel but I had the same issue with my Onkyo...It is a station issue and not an equipment issue from what I can tell...
The 1910 also looks rather 'blah' to me...Just not very impressive looking from what I see...Though the back panel certainly has a 'clean' look to it...But thats what the omission of all the 'S' video ports will do...
Finally it looks like the 1910 use 3/10 of an amp more than the 789/1909...Doesn't sound like much but all the little 'extra' amounts add up you know...
Yes...I have to concede the 789/1909 (same thing for argument sake) is the better of the 2 models hands down...
