Originally Posted by
Xylon
Which one has less and more?
Xylon...when theres more detail on HD DVD, it's called compression artifacts
Seriously though. If you look at the 2nd frame, where all the horses are, you can see the same effect in the sky between the sets of horses. It's evident if you look up and a little to the right of the circled scratch. Also if you follow the dust trail (to the right of the vertical scratch) to the area before the last set of horses, there is an area where the dust blob is sorta white and sandy...the same effect can be seen in that. It's subtle, but it's there.
