AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Bluray Player Audio Support Comparison Chart
Bluray Player Audio Support Comparison Chart - Page 9
post #241 of 662
Originally Posted by adidino View Post
Really? I can see it. Anyone else?
No chart
Did you mean to put the chart a personal server? I don't recommend that. Have you tried MSN live to host the chart?
http://69.125.154.86/website/bd%20chart%201006.PNG
post #242 of 662
Do you have a link for the hosting area?
post #243 of 662
Originally Posted by EWL5 View Post
Yeah but it doesn't decode. We are strictly talking about lossless decoding players.
Yes it does.
S~
post #244 of 662
http://skydrive.live.com/?mkt=en-us
Then click "Get Started".
Put the image in your public area. The link to the upload file will be provided.
post #245 of 662
Originally Posted by teachsac View Post
Yes it does.
S~
I see from this website that they've lumped the 35 and 55 together in describing MA decoding ability:
http://panasonic.net/avc/blu-ray/dmp...nticsound.html
If this is true, then the BD35 mimics the PS3 in its ability to decode all over HDMI. What's the pricing on the BD35? I must have confused this player with the Sony S350, which does not decode MA internally.
post #246 of 662
The 35 and 55 are said to be $299 and $399, respectively.
Not bad at all considering what the 30 and 50 are still selling for.
post #247 of 662
MA decoding for $299 is incredible if it pans out!
post #248 of 662
I know. I've had $600 allocated thinking I was going to get the BD-50 a while back. My money is going on the BD-35 and I'll be $300 richer!
post #249 of 662
So I added the latest chart and... I'm sure I'm missing some things. If I'm missing anything... let me know and I'll add it.
Yeah, the chart is missing... please add it. Thank you
post #250 of 662
I can't see it either.
Ed
post #251 of 662
Ed
Ditto.
If you can see it and we can't then that means it's only being hosted locally on your network.
post #252 of 662
I'll get this resolved by tonight...
post #253 of 662
Nope - its gone.
post #254 of 662
OK.. So I uploaded it to MS Live for now. Let me know if any data is missing on the chart that I need to add.
post #255 of 662
There's just a few MSRP changes that should be made:
Panasonic DMP-BD30: $399
Panasonic DMP-BD50: $599
Samsung BD-P1500: $299
Sony BDP-S350: $299
post #256 of 662
Image looks good.
You might want to update the initial post's text:
LATEST EDIT (2.0 July 19 2008): Updates to Sony BDP-S350, Pioneer Elite 51FD,05FD, Samsung BDP1400, BDP1500, Panasonic DMP-BD50, BD30, Samsung BD-UP5000
post #257 of 662
Originally Posted by WhatHappend View Post
Image looks good.
Thanks.. I will. I'll wait for a few more comments on the chart and make more updates over the weekend.
MSRP changes notes as well.
post #258 of 662
Nice chart update.
I suggest you include the upcoming Panasonic DMP-BD 35 and 55
Specs:
http://www.panasonic.net/avc/blu-ray...fications.html
Press Release:
http://www2.panasonic.com/webapp/wcs...22008020836975
post #259 of 662
post #260 of 662
The Sony S300 with the latest firmware (4.2) appears to be like the 95FD in that it doesn't use Dolby THD for its analog outputs, HDMI only. Playing back a 96kHz BluRay disc and I get 96kHz over HDMI but internally the DACs are being fed at 48kHz.
Shawn
post #261 of 662
What disc has TrueHD at 24/96?
All the TrueHD tracks up to this point are 24/48 AFAIK, so assuming this is true, this tells you nothing about whether TrueHD is being output via analog. Most lkely what is happening is that the HDMI output is being upsampled from 48khz (which is probably a bad thing anyway; you most likely would be better off with the native sample rate input to your avr).
post #262 of 662
Dave Matthews and John Mayer BR are TrueHD 24/96.
post #263 of 662
is the chart right? the marantz 8002 does dts hd hr and dd+ over analog but the denon doesn't????
post #264 of 662
"What disc has TrueHD at 24/96?"
Dave Mathews and Tim Reynolds at Radio City Music Hall.
Play that back on the BD50, BDP-51FD, BDP-05FD and the dacs are all fed at 96kHz.
Play that back on the BDP-95FD (which is known to not use TrueHD for its analog outputs) and the dacs are fed at 48kHz. The S300 is the same.
Shawn
post #265 of 662
Shawn
Ok fair enough. The question though is what is actually happening. Maybe 96khz is simply being downsampled to 48 for analog. That would arguably (don't want to argue though) not make an audible difference and only apply to a few titles at this point.
How again can you tell that 48khz is being fed to the DAC's for analog? I have an s300 but I simply can't remember.
post #266 of 662
"How again can you tell that 48khz is being fed to the DAC's for analog? I have an s300 but I simply can't remember."
You have to open it up and measure it. The S300 uses PCM1791 DACs. Pin 1 on those DACs is the Left/Right clock. That clock cycles once per sample. IOW that clock runs at the sampling rate of the signal going to the DACs. R051 is connected to Pin 1 on the PCM1791. Measure that clock with a frequency counter or a scope and you know the sampling rate of the data going to the DAC.
The attached show this on the S300 when playing back the Dave Matthews BluRay with the 96kHz track selected. The S300 DACs are being fed at 48kHz, the core data rate just like the 95FD.
Shawn
post #267 of 662
Sounds like you know your stuff.
But how can you tell whether the DAC's are being fed 96hz TrueHD downsampled to 48 vs. the core?
I know the Tosh XA2 upsamples 48 to 96 so it would seem also plausible that a player might downsample 96 to 48 (for whatever reason).
post #268 of 662
Killer Chart. Keep it Up, PLEASE add the Pany 35/55
post #269 of 662
adidino, you rock.
It is posts like this that really make a site. There is no freaking way I would have had the patience to wade through the documentation or various links to answer the basic questions you have done for us. Thanks.
A request: given what we do/don't know about the upcoming Oppo unit (guessing Q109), could you put that in? I believe it will be complete across the board, 7.1/7.1, and 2.0. The MSRP is unknown at this point.
post #270 of 662
You have the basic specs on the 30/35? I can add it.
