AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Bluray Player Audio Support Comparison Chart
Bluray Player Audio Support Comparison Chart - Page 11
post #301 of 662
Originally Posted by SUOrangeman View Post
Quick sanity check.
I've tried to make the updates per the posts from the last month as well as all BR players currently listed on Amazon and Crutchfield. I only tried to fill in the fields that were clearly stated from those three sources. Therefore, I've got plenty of blank space to fill. See the third worksheet for the specific additions/changes
Please take a look and PM me any corrections.
By the way, how does this thread compare to this link?
-SUO
This chart is easier to read because of the feature being in the block of color and not just at the top. It also tells about streaming capabilities.
post #302 of 662
Quick sanity check.
-SUO
Time to add DSD and DVD-Audio to the matrix since the Oppo will support them. Kinda makes the rest look bad (not a bad thing).
post #303 of 662
could you please update the chart with the LG BD300
post #304 of 662
Interesting that chart indicates the Pioneer 05FD will decide DTS MA but the 51FD does not? They are both the same player with the exception of the video proc and chasis.
http://www.blu-ray.com/players/compa...action=compare
post #305 of 662
Thanks for adding SACD and DVD-Audio. Nice to see the no in red for all the existing players (except the early PS3s from Sony for SACD playback albeit with LPCM output).
post #306 of 662
Where is the current comparison chart? It's not the chart that's on page 1 of this thread, is it?
post #307 of 662
Audio decoding question. I have my samsung 1400 connected to my Halo C2 processor via Digital toslink. I have the 1400 sending bitstream. One thing I noticed, is I will not be able to decode True HD becasue the signal is not sent via digital.
Is this correct and do you need a processor that decodes the new audio formats??
post #308 of 662
Like AVS, Blu-ray.com is an AV enthusiast-based site so take everything with a grain of salt. Currently both the 51 and 05 do not decode MA. The update is scheduled for Jan 09 or Feb 09, depending on which website article you believe.
That chart also has the post processor as being identical for the 05 and the 09, which is not true. Only the 09 will have Marvell's Qdeo.
post #309 of 662
For the 1,000,000 time on any bluray player forum, the new high resolution audio formats only bit-stream over HDMI.
High resolution audio formats include DD+, TrueHD, DTS HR, DTS MA, multi-channel PCM.
Without a HDMI AVR, no digital form of high resolution audio formats can be heard. Multi-channel high resolution analog decoding is possible with certain Bluray players (see chart on post 1).
post #310 of 662
Same question. This thread is getting confusing having multiple charts.
post #311 of 662
Google Docs.
OP, please add a link to the Google Docs in the OP.
Here is the post that explains the new docs location: http://www.avsforum.com/avs-vb/showt...3#post15017523
post #312 of 662
Originally Posted by WhatHappend View Post
Google Docs.
Thanks. Didn't think that was the most updated version because it doesn't include players such as Panny 35/55, new LG 300, etc.
post #313 of 662
Sure does... You must not have read the posts pertaining to that chart.
Try sheet 2.....
post #314 of 662
Try sheet 2.....
I think I'm a little dense as I don't see a sheet 2.
Edit: I see it now. You have to click on appended and sorted, right?
Edit: The Sony BDP-S550 availability should be listed as "now".
post #315 of 662
Try sheet 2.....
D'oh! Thanks again
post #316 of 662
Shouldn't the Panasonic DMP-BD 35 be listed as "complete" all the way across?
post #317 of 662
Yes, the BD 35 should be "complete" across.
post #318 of 662
Yes the DMP-BD 35 is complete and I love this player. Replaces the PS3
post #319 of 662
I corrected the Panasonic DMP-BD35 line in the GoogleDocs version. I've also updated the availability of the Sony BDP-S550.
As others have noted, I left the original chart as the first worksheet and am only making changes on the second. I'm logging those changes on the third worksheet.
-SUO
post #320 of 662
Cant wait to get my 35!
post #321 of 662
I don't see the panny 55 on there
post #322 of 662
If you are talking about Panasonic BD55, it is on the new audio support spreadsheet.
Either you are blind or you refuse to read the last 10-15 posts.
Thanks SUOrangeman for your updates.......
post #323 of 662
Speaking solely for the Denon 3800 and Marantz 8002 (don't know about the 2500), the "L" designation under HDMI (PCM) should be further clarified. It should say that the LFE channel will have 5dB less than the other channels when any speakers have been set to SMALL. This 5dB deficiency will not be there if all speakers are LARGE or if Source Direct is ON.
The Denon 3800/Marantz 8002 is unique in that this known analog limitation has carried over into the digital realm because of how much flexibility these machines have provided in audio.
Also, the Denon 2500 and 3800 should probably read (L,LF) since there was an LFE bug but this has been corrected by latest firmware. Don't know if the Marantz debut with this bug as the owner's thread hasn't been very informative.
post #324 of 662
The OP should put the link in the first post.
post #325 of 662
Agreed
post #326 of 662
Agreed
I can do it. I think the only issue is it would be a link on the first post as opposed to a chart.
post #327 of 662
I think the easiest thing is for me to post the latest chart but new announcements are getting ahead of me. Who wants to work with me for about 30min or so over the phone and get this chart updated with me?
post #328 of 662
I can't see neither BD35 nor BD55 there.
I mean I looked at list at 2 spreadsheats
here
http://www.avsforum.com/avs-vb/showthread.php?t=1050507
and here
http://www.avsforum.com/avs-vb/showthread.php?t=980672
and none of them have latest Pannys included.
Could somebody kindly post the link to the chart with them included?
post #329 of 662
Originally Posted by purumpum View Post
I can't see neither BD35 nor BD55 on this chart.
here http://www.avsforum.com/avs-vb/showthread.php?t=1050507
and here http://www.avsforum.com/avs-vb/showthread.php?t=980672
and none of them had latest Pannys included.
At the bottom of the Google docs chart, click where it says "appended and sorted".
post #330 of 662
What is "google docs chart" ? The chart appears as png image in the first post of the thread. Filename "bdchart.png". There is no any interaction in it.
