Racing Cabinet
post #1 of 6
Folks,
Check out my latest project:
http://www.thetheos.com/racingcab.html
I am nuts.
post #2 of 6
that's pretty sick! Too bad the wireless wheel isn't of a higher quality, not your fault of course
post #3 of 6
Thanks for the comments. The wheel isn't too bad IMO. I mounted it by drilling through it. I put long bolts through the drilled holes and into the wood shelf.
I just wish that game would support it better. Forza 2 and Burnout Paradise City work very well with it. Need for Speed Carbon is almost unplayable. If you could adjust the sensitivity it would play a lot better. On Carbon, you barely move the wheel and the car moves a lot.
post #4 of 6
dang dino u rule, go av123!
post #5 of 6
I always wanted to build something like this with like a shifter and whatnot.
post #6 of 6
That is way cool! Excellent work!
