AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › DTA800B Codes
DTA800B Codes
post #1 of 28
Does anybody have the manual containing the program codes for the DTA800B box. It seems it can't be found anywhere on the internet. I'm looking for the codes for a Sanyo and RCA tv.
post #2 of 28
Sanyo: 037, 082, 083, 124, 198, 268, 274
RCA: 000, 001, 005, 072-078, 135, 138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302
(whew)
post #3 of 28
Thank you. I'll be sure not to lose these.
post #4 of 28
Here's another dummy who lost his DTA800 manual.
Any one have the programming codes for Samsung TV's?
post #5 of 28
Samsung: 005, 013, 079, 080, 145, 177, 195, 202, 213, 216, 227, 255, 256, 260, 266, 274, 275, 282, 295
post #6 of 28
Thanks richardav. That did the trick.
post #7 of 28
i am also a dummy that lost there manual can i possibly get the codes and instructions for programing my remote for a sanrio tv
post #8 of 28
Dead Dot: Good luck with that! It is not in my DTA800 chart.
post #9 of 28
What about codes to control the DTA800B1 box from a universal remote?
post #10 of 28
Hi i threw my manual away thinking i would never need it again. turns out i was wrong and when you replace the bateries you have to reprogram it apparently. So does anyone have the codes for a Symphonic TV? please help i cant change the input to whatch dvd's till i get this code
post #11 of 28
Symphonic: 027, 139, 185, 186
post #12 of 28
Isn't there a place where one can just download a new manual?
It can't be that large.
post #13 of 28
Can anyone tell me the programing process? i have the codes i just dony know how to use them
post #14 of 28
Press PGM on the remote control. Enter the 3-digit code. Press OK. Test to see if it works. If not, try the next code.
post #15 of 28
The codes aren't in the manual -- they are on a separate single sheet which, judging from this thread, apparently gets lost easily.
post #16 of 28
Originally Posted by richardav View Post
..which, judging from this thread, apparently gets lost easily.
..or gets thrown out.
post #17 of 28
How about someone scan an image of that bad boy in here? Or this could go on for a while...
post #18 of 28
I don't have a scanner, but maybe some photos would serve:
post #19 of 28
Thanks for the post! I didn't realize that RCA would have like 30 codes.
post #20 of 28
God bless you for posting pictures of the codes! I've been trolling the web looking for these codes for months.
post #21 of 28
Nobody knows?
post #22 of 28
Nobody knows?
Depends on the remote - you'd have to look in it's printed code listings, which would either be in it's manual, or on a separate piece of paper that came with it. If it's not listed under RCA, GE, Proscan or whatever, you could try the code search feature, which will also be explained in the remote's manual.
Now, if you don't still have the remote's manual, then shame on you.
Maybe you can find it and download it online.
post #23 of 28
DTV converter boxes are too new to be included in URC manuals or lists.
I could try guessing at some of the other RCA codes, or possibly doing the code search, but if somebody here already has them.........
post #24 of 28
Not totally true - the Channel Master (Pioneer cable box code) and the DTVPal (Scientific Atlanta cable box code) can be found in most remotes, and the Zenith and RCA (satellite box codes) can be found in some newer ones.
You can get learning remotes for less than $15.00 these days, too.
post #25 of 28
I can control the DTA800B1 with the remote that came with my Panasonic TV with DBS code 106. Someone on another thread said that code 808 worked with a Sony remote.
post #26 of 28
thank you for the codes for dta800 remote
post #27 of 28
Admiral 002, 128, 183, 189
Advent 191, 258, 260, 275
Adventura 129
Aiko 014, 182
Aiwa 289, 290
Akai 003, 177, 195, 201, 202, 295
Albatron 218
Alleron 036
America Action 186
Amtron 186
Anam 186
Anam National 141, 142, 186
AOC 005, 130, 143, 177, 260, 274, 275
Apex 053, 172, 184, 192, 232, 250, 280
Audiovox 182, 186, 188, 207, 223, 234
Aventura 185
Belcor 274
Bell & Howell 002, 037, 198
Benq 204, 306
Bradford 186
Brillian 236, 237, 238
Brockwood 274
Broksonic 186, 189, 200
Candle 005, 007, 129, 177, 274
Carnivale 177
Carver 181
Celebrity 003, 175
Celera 053, 192
Centurion 008
Changhong 053, 192
Citizen 005,007,014, 037,080, 148, 177, 182, 186, 195, 198, 274
Clarion 186
Colortyme 005, 009, 274
Commercial Solutions 178
Concerto 005, 274
Contec 186
Conte_Cony 186
Craig 186
Crosley 181
Crown 045, 186
CTX 304
CurtisMathes 001,005,013,037,080, 148, 156, 159, 177, 178, 181, 183, 188, 195, 196, 198, 199, 202, 205, 229, 274, 295
CXC 186
Cytron 309
Daewoo 005,014,015, 016, 095, 140, 182, 188, 201, 207, 233, 260, 274, 275
Daytron 005,274
Dell 181
Denon 196
DiamondVision 243
Dimensia 001
Dumont 176, 245, 274
Durabrand 173, 185, 186, 189, 274
Dwin 183, 212,214
Electroband 003, 175
Electrograph 193
Electrohome 003, 005, 017, 018, 274
Emerson 005,019, 020, 021, 022, 023, 024, 025, 026, 027, 028, 029, 030, 031, 032, 033, 034, 035, 036, 037, 093, 132, 140, 149, 157, 161, 169, 174, 185, 186, 189, 198, 200, 207, 274
Envision 005, 177, 215, 274
ESA 185, 202
Fisher 037, 198
Fujitsu 036
Funai 036, 139, 185, 186
Futuretech 186
Gateway 193, 204
GE 21 001, 005, 018, 039, 040, 053, 063, 122, 123, 135, 149, 163, 178, 179, 188, 229, 232, 249, 250, 274
Gibralter 042, 176, 177, 245, 274
GoVideo 224
Goldstar 005, 041, 042, 116, 117, 177, 260, 274, 275
Grunpy 036, 186
Haier 173, 242
Hallmark 005, 274
Harman/Kardon 181
Harvard 186
Havermy 183
Hello Kitty 188
Hisense 190
Hitachi 005, 043, 044, 100, 101, 102, 103, 105, 107, 110, 111, 112, 155, 165, 166, 167, 168, 169, 196, 248, 274, 276, 284
IMA 186
Infinity 045, 181
Insignia 189, 244, 309
Inteq 176
Janeil 129
JBL 045, 181
JCPenney 001, 005, 007, 018, 039, 040, 042, 053, 063, 079, 080, 135, 163, 260, 274, 275
JCB 003, 175
Jensen 005, 191, 258, 260, 274, 275, 309
JVC 040, 044, 046, 047, 048, 118, 119, 136, 157, 180, 263, 264, 271, 287, 292, 296
Kawasho 003,005,274
KEC 186
Kenwood 005, 177, 274
KLH 053, 192, 232
Kloss Novabeam 049, 050, 129, 186
Konka 194
KTV 051, 132, 177, 186
LG 221, 260, 274, 275
Loewe 045
Logik 002
Luxman 005, 274
LXI 001, 005, 037, 045, 052, 053, 135, 147, 163, 178, 181 184, 198, 274
Magnavox 005, 007, 045, 049, 050, 054, 055, 064, 097, 098, 099, 153, 154, 160, 170, 174, 177, 181, 210, 230, 234, 252, 253, 258, 259, 272, 274, 283
Majestic 002
Marantz 005, 043, 045, 057, 177, 181, 220, 230, 274
Matsushita 187
Maxent 193
Megatron 005, 043, 196, 274
Memorex 002, 005, 037, 139, 185, 189, 197, 198, 260, 274, 275, 283
MGA 005, 018, 058, 177, 197, 260, 274, 275
Midland 040, 135, 163, 176, 178, 179, 245
Minutz 039
Mitsubishi 005, 018, 058, 094, 183, 197, 217, 260, 262, 274, 275
Monivision 218
Montgomery Ward 002
Motorola 128, 183
MTC 005, 080, 177, 195, 260, 274, 275
Multitech 186
Multivision 061
NAD 005, 052, 053, 137, 155, 184, 274, 291
NEC 005, 009, 177, 206, 260, 274, 275
Net-TV 193
Nikko 005, 014, 117, 182, 274
Norcent 190
NTC 014, 182
Olevia 239, 240
Onwa 186
Optimus 137, 155, 187, 198, 199
Optoma 225
Optonica 071, 128, 183
Orion 029, 189, 200
Panasonic 040, 045, 125, 179, 187, 254, 257, 288, 299, 301
Penney 001, 177, 178, 179, 184, 195, 229, 274
Philco 005, 007, 045, 049, 050, 054, 177, 181, 260, 274, 275, 283
Philips 007,045, 049, 050, 054, 062, 063, 064, 065, 181, 185, 209, 230, 252, 258, 261, 267, 269, 272, 273, 274, 277, 278, 281, 285, 286, 297, 300, 305
Philips Magnavox 181, 185, 230, 253, 258, 270, 273, 279
Pilot 177, 274
Pioneer 005, 066, 067, 068, 137, 155, 169, 171, 199, 274, 291, 294
Polaroid 053, 192
Portland 005, 014, 182, 260, 274, 27S
PriceClub 080
Prima 191, 258, 260, 275
Princeton 211
Prism 040, 179
Proscan 001, 135, 163, 178, 229, 249
Proton 005,069, 205, 274
Proview 241
Pulsar 176, 245, 274
Quasar 040, 051, 070, 125, 179, 187, 254, 257
Radio Shack 001, 037, 177, 178, 186, 198, 274
Radio Shack/Realistic 001, 005, 037, 071, 186, 198, 274
RCA 000, 001,005, 072, 073, 074, 075, 076, 077, 078, 135, 138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302
Realistic 001, 037, 177, 186, 198, 274
Runco 176, 177, 206, 245
Sampo 005, 177, 193, 274
Samsung 005, 013, 079, 080, 145, 177, 195, 202, 213, 216, 227, 255, 256, 260, 266, 274, 275, 282, 295
Sansui 189
Sanyo 037, 082, 083, 124, 198, 268, 274
Scotch 005, 274
Scott 005, 020, 029, 036, 186, 200, 274
Sears 001, 005, 036, 037, 047, 052, 053, 084, 135, 139, 163, 178, 181, 184, 185, 198, 232, 274
Sharp 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
Sheng Chia 183
Shogun 274
Signature 002, 019
Simpson 007
Sony 003, 146, 151, 152, 175, 228, 247, 251, 303, 308
Soundesign 005, 007, 036, 186, 274
Squareview 139, 185
SSS 186, 274
Starlite 186
Studio Experience 218
Superscan 183
Supre-Macy 129
Supreme 003, 175
SVA 242
Sylvania 005, 007, 045, 049, 050, 054, 055, 064, 088, 121, 139, 174, 177, 181, 185, 274, 307
Symphonic 027, 139, 185, 186
Syntax 239, 240
Tandy 128, 183
Tatung 204
Technics 040, 179, 187
Techview 219
Techwood 005, 040, 179, 274
Teknika 002, 005, 007, 014, 036, 055, 080, 125, 181, 182, 186, 195, 197, 260, 274, 275
Telefunken 202, 295
TMK 005, 274
TNCi 176
Toshiba 037, 052, 053, 080, 090, 121, 184, 195, 198, 231, 232, 265,274
TVS 189
Universal 039, 063
V Inc. 235
VectorResearch 177
Victor 047, 136, 180
Vidikron 181
Vidtech 005, 260, 274, 275
Viewsonic 193, 222, 235
Viking 1290
Vizio 204, 235
Wards 001, 002, 005, 020, 027, 036, 039, 045, 049, 050, 054, 055, 063, 064, 071, 091, 177, 181, 231, 260, 274, 275, 291
Waycon 184
Westinghouse 175, 188, 226, 235
White Westinghouse 140, 189, 207
Yamaha 005, 177, 260, 274, 275
Zenith 002, 113, 114, 115, 176, 182, 189, 245, 248, 274
post #28 of 28
there are good people in the world ! definitely not the manufacturers because they don't even provide a code list ! FAIL !
