AVS › AVS Forum › Video Components › Video Processors ›  DVDO EDGE !!
DVDO EDGE !! - Page 225
post #6721 of 7061
HDFury 3 -
I assume you want this for classic gaming, if so you're going through so many video processors that I'd be worried about lag. The Edge does have S-Video input, and if that works it might be a better (and cheaper) way to go. Also, 240p is kinda low resolution and meant for 19" TVs. I think the scan lines would be huge on most big screen TVs these days. I hated them on 50" TVs back in the 90's.
post #6722 of 7061
I don't know what this looks like but I hear it doesn't make 240p content look good at all.
on 240p content the Edge causes halos around object outlines. More pronounced on the vertical than on the horizontal.
and I came upon getting an HD Fury 3 which is necessary to connect
the Fury 3 is a bit expensive for this kind of use. You'd be ok with a Fury 1 or even a gamer edition Fury 1. Just stay away from the Fury 2 as the SLG3000 is not compatible with the Fury's sync polarities.
SLG3000 -> VGA to Component/HDMI cable -> 43" Samsung HDTV
this doesn't work. There is no easy way to connect the SLG's VGA output to a TVs component or HDMI input.
So I came upon this alternative:
as said, the Fury 2 is not compatible with the SLG3000, so there's always a chance that other devices aren't compatible either.
would it be alright if I used a VGA to Component cable from the SLG3000 directly to my display?
does not work.
Given your existing setup (Edge + VGA-less Samsung TV) I would recommend you keep the Edge last in the chain. What kind of 240p sources do you want to use ? I would simply get a GBS8220 from ebay ($40) or a HDBoxPro clone from monoprice ($38) and use the chain like this:
Source > GBS8220 > SLG3000 > EDGE > TV
Save yourself the money for the Fury...
post #6723 of 7061
Okay, this is a shorter version of my response since I took the discussion to shmups instead.
Yeah, I'm guessing the HD Fury Gamer Edition would be a good enough solution.
does not work.
Okay, but how would I go about connecting the SLG3000 to the Edge then? I'm assuming the HD Fury Gamer Edition would suffice?
post #6724 of 7061
The Fury only works in one direction (DVI/HDMI to VGA), not the other way around. The Edge already has a VGA input. If you decide for the suggested processing chain, you don't need a Fury at all.
post #6725 of 7061
Well the reason I mentioned the HD Fury was because you stated that the Edge would only be compatible with the SLG3000 according to it's compatibility as quoted from the SLG3000 thread.
- What about 240p or 480i from classic videogame systems ?
To "scanline" those you need an deinterlacer/upconverter/scaler between the source and the SLG3000. Refer to http://retrogaming.hazard-city.de/ for available machines. Confirmed to be working with the SLG3000 are:
- DVDO processors like the iScan Pro, Ultra, HD, Vp30 or Edge (Edge only with additional HDFury)
I also read this, I assume I would need a VGA to RGB cable to hook up the SLG3000 to the Edge?
How do I connect VGA or SCART devices to the DVDO Edge?
At the back of the Edge are several RCA/phono type connectors. This is the Edge's flexible analogue video input. In order to keep costs/size down, Anchor Bay designed the Edge to accept several types of input through these connectors. Component video can connect directly. For VGA, you will need a VGA to RGBHV cable. Unfortunately these cables typically feature BNC connectors instead of RCA. You can obtain BNC to RCA converter plugs, or you can have a cable custom made. Ask for a VGA to RGBHV 5 RCA cable and most custom cable shops worth their salt will understand and fulfil your wish.
post #6726 of 7061
You need a HDFury if you want to use the SLG *BEHIND* the Edge, but since your TV does not offer VGA, that's not a very good solution on your setup.
And, yes you need a VGA to RCA breakout cable to put the SLG *BEFORE* the Edge.
post #6727 of 7061
Okay, would this breakout cable do the job then? It seems there are others of BNC type but these are of the RCA type, with black and white which is what I need?
http://www.ebay.com/itm/VGA-SVGA-HD1...#ht_2591wt_689
Or
Monster VGA to RCA component cable?
http://www.ebay.com/itm/Monster-Cabl...0#ht_500wt_922
post #6728 of 7061
The first one works, the second one does not.
post #6729 of 7061
Okay, I will be getting my Edge in a couple of days, anyway, I've been researching more about the Edge in regards to Anti-Aliasing, would it do it good job on 480i/480p content to get rid of those "jagged" edges? I'm having this issue with Wii games, also, would my Wii benefit more if I switched my setting from 480p to 480i as far as picture quality is concerned? I'm well aware that 480 de-interlaced with introduce lag (56ms) without gamemode versus 480p (any lag?)
post #6730 of 7061
I had a JVC G15 for years (1360x768). 1080i on it looked really good. Football games were eye candy.
I have just replaced the G15 with a JVC RS-40, which is 1920x1080P.
Now 1080i content looks worse than it did with the old projector (1080p content like BD disks look awesome).
So do I need a video processor to fix this, and if so which one?
post #6731 of 7061
Okay, I just got my Edge and so far I'm impressed, although I'm having an audio issue via component, the thing is that I have component cables (YCbCr + L/R) for both my PS2 and Wii hooked up into the Edge via RGB, I am aware that there is an analog stereo input as well and I hook up the L/R cable in it for sound, after doing so I found that I indeed get sound from my sources, however the problem I'm having is that everytime I start up a different game the Edge only displays video, but for some reason the audio is muted everytime, this includes whenever the Edge sync's into different display resolutions, most notably with 240p content, anyway it's a real hassle having to go into the DVDO audio settings and selecting the stereo input option everytime I want to get sound going from either my PS2 or Wii, so is there any option for stereo audio to always be working without having to manually select it from the Edge settings every single time?
post #6732 of 7061
Other than losing one HDMI input (which I never used anyway), is there any reason not to go for the DVDO Edge Green over the original? Anyone who has experienced both care to chime in? Just wondering if one gives a better image quality result over the other. They also have different firmwares. Any opinions would be greatly appreciated!
post #6733 of 7061
I'd really hate to give up that front HDMI input. It is really useful when I want to temporarily plug in a laptop, or a friend come over with his XBox 360.
post #6734 of 7061
Well the front of my TV has HDMI so I just use that. I use the Edge for more of an upscaler than I do an A/V switch.
Which is why I am wondering if it's silly to get the old DVDO Edge or not. I'm assuming the green is built a bit differently since it cannot use the old Edge firmware. But the Green might be better picture quality; I have no idea. Would love to know if someone here did.
Also, maybe the Green correctly detects 240p source material (something the original has not done in quite a few firmwares).
post #6735 of 7061
currently the Green can't handle 240p at all. Ken at SimplayLabs knows about it (he confirmed the bug in early october), but I haven't heard back from him yet on a possible fix.
post #6736 of 7061
Holy hell! That's huge! But...it also tells me the Green is a good deal different than the original Edge. Who knows....maybe when there is a firmware update to fix it, it will correctly detect it and I won't have to use firmware from 4 years ago any longer like I do on the original. This is why I am hesitant to buy another Edge, before figuring out which one is better.
Edit: So if you plug in an SNES via s-video into a DVDO Edge Green, it literally will not display a picture??
post #6737 of 7061
Is there any way to make the Edge automatically switch between 24/1080P and 60/1080P? Hate going into the menu each time to change.
Gary
post #6738 of 7061
Gary
you need to enable 1:1 frame rate and it should work for you......
post #6739 of 7061
If you're interested, here's what a 240p signal looks like on the Edge GREEN:
http://pms.hazard-city.de/edge_green_240p.mov
post #6740 of 7061
Gary
As 1forsnow points out, you need to enable 1:1 frame rate. What this does is match the frame rate to the source, so when you play a blu-ray disc, the Edge outputs 24 Hz/1080p and when you play a DVD it outputs 60Hz/1080p - all automatically.
post #6741 of 7061
Thanks to both you and Keith, worked like a charm
post #6742 of 7061
Pleasure. Glad it's working for you now.
post #6743 of 7061
It is very likely that the only differences in the firmware for the EDGE and EDGE Green are to support the different hardware. For example, you wouldn't want an 'HDMI Front' input in the OSD for the EDGE Green.
post #6744 of 7061
I thought of that except it wouldn't explain why video game systems released before the Playstation 2 do not work on the Green and they work just fine on the older unit.
Thanks so much for posting this. I was very close to buying a Green. Now I am considering buying another non-Green Edge. Except I am worried it will no longer be supported and not get firmware updates. I am also worried the Frame Meister will come out and kick ass, and make me regret buying another Edge! What to do, what to do...
post #6745 of 7061
Hey all
I love my DVDO Edge but I think the menu system is a bit unwieldy, lots of button clicks to get into the Advanced Settings submenu to change anything useful. So I was happy to learn that almost all of the Edge's functions can be controlled by discrete remote codes. These can be programmed directly if you have a Pronto-compatible remote, or if you have a Harmony then you can email Logitech and get them to add the codes to your profile (you can add them yourself but it's a pain).
It seems these were readily available on the old forums but I had trouble getting hold of them when I looked recently. In the end I found Barry Gordon's excellent DVDO IR Generation program which is still available on his website and generated all or almost all of the codes for the Edge (new discrete codes may have been introduced in recent firmware, I'm not sure). But in case anyone doesn't have Windows I thought I'd list all the codes here as actual text rather than a link to an offsite file that might disappear.
Hope they're useful to someone. I've been getting a lot of use out of the discrete output modes, turning the 1:1 frame lock on and off, and switching the HDMI audio output between audio-video and audio-only output, which has the effect of routing audio straight through to my TV or through the amplifier.
Code:
IR Data For Command Video Input Select = Auto  (0x4C/76  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = Video  (0x4C/76  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = S-Video  (0x4C/76  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = Component1  (0x4C/76  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = Component2/PC  (0x4C/76  '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-1  (0x4C/76  '5'/53)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-2  (0x4C/76  '6'/54)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-3  (0x4C/76  '7'/55)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-4  (0x4C/76  '8'/56)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-5  (0x4C/76  '9'/57)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-Front  (0x4C/76  '10'/49,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Video Input Select = Off  (0x4D/77  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Auto Video Input Select = On  (0x4D/77  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Brightness(0x21/33) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Brightness(0x21/33) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Brightness(0x21/33) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Contrast(0x22/34) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Contrast(0x22/34) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Contrast(0x22/34) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Saturation(0x23/35) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Saturation(0x23/35) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Saturation(0x23/35) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Hue(0x24/36) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Hue(0x24/36) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Hue(0x24/36) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Fine Detail(0xC8/200) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Fine Detail(0xC8/200) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Fine Detail(0xC8/200) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Edge Enhancement(0xC9/201) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Edge Enhancement(0xC9/201) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Edge Enhancement(0xC9/201) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = Off  (0xCA/202  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = Low  (0xCA/202  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = Medium  (0xCA/202  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = High  (0xCA/202  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command YC Delay(0x27/39) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command YC Delay(0x27/39) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command YC Delay(0x27/39) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Horizontal Zoom(0x40/64) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Horizontal Zoom(0x40/64) Middle of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Horizontal Zoom(0x40/64) Maximum of Range=100.0
0000 006C 003B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Vertical Zoom(0x41/65) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Vertical Zoom(0x41/65) Middle of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Vertical Zoom(0x41/65) Maximum of Range=100.0
0000 006C 003B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Horizontal Pan(0x42/66) Minimum of Range=-240
0000 006C 0033 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Horizontal Pan(0x42/66) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Horizontal Pan(0x42/66) Maximum of Range=240
0000 006C 002B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Vertical Pan(0x43/67) Minimum of Range=-240
0000 006C 0033 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Vertical Pan(0x43/67) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Vertical Pan(0x43/67) Maximum of Range=240
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Overscan(0x46/70) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Overscan(0x46/70) Middle of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Overscan(0x46/70) Maximum of Range=100.0
0000 006C 003B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = HDMI  (0x4A/74  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Coaxial  (0x4A/74  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Toslink-1  (0x4A/74  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Toslink-2  (0x4A/74  '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Toslink-3  (0x4A/74  '5'/53)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Stereo  (0x4A/74  '6'/54)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Delay(0x4B/75) Minimum of Range=-56
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Delay(0x4B/75) Middle of Range=72
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Delay(0x4B/75) Maximum of Range=200
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = Auto  (0x61/97  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 480i  (0x61/97  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 576i  (0x61/97  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 480p  (0x61/97  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 576p  (0x61/97  '4'/52)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 720p50  (0x61/97  '5'/53)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 720p60  (0x61/97  '6'/54)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080i50  (0x61/97  '7'/55)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080i60  (0x61/97  '8'/56)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p24  (0x61/97  '9'/57)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p25  (0x61/97  '10'/49,48)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p48  (0x61/97  '11'/49,49)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p50  (0x61/97  '12'/49,50)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p60  (0x61/97  '13'/49,51)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = VGA60  (0x61/97  '14'/49,52)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = SVGA60  (0x61/97  '15'/49,53)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = XGA60  (0x61/97  '16'/49,54)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = SXGA60  (0x61/97  '17'/49,55)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Display Active Ratio = Auto  (0x6A/106  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Display Active Ratio = 16x9  (0x6A/106  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Display Active Ratio = 4x3  (0x6A/106  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Underscan(0x8B/139) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Underscan(0x8B/139) Middle of Range=10
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Underscan(0x8B/139) Maximum of Range=20.0
0000 006C 0033 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = Auto  (0x6C/108  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = RGB  (0x6C/108  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = YUV422  (0x6C/108  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = YUV444  (0x6C/108  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Colorimetry {601/709} = Auto  (0xE5/229  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Colorimetry {601/709} = 601  (0xE5/229  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Colorimetry {601/709} = 709  (0xE5/229  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Dynamic Range = Auto  (0xE6/230  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Dynamic Range = Video  (0xE6/230  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Dynamic Range = Computer  (0xE6/230  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Input Dynamic Range = Auto  (0xF0/240  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Input Dynamic Range = Video  (0xF0/240  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Input Dynamic Range = Computer  (0xF0/240  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Power = Off  (0xA1/161  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Power = On  (0xA1/161  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Standby = Off  (0x83/131  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Standby = On  (0x83/131  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Wake Up = Off  (0x2E/46  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Auto Wake Up = Mode-1  (0x2E/46  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Auto Wake Up = Mode-2  (0x2E/46  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Off  (0x80/128  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Frame Geometry  (0x80/128  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Brightness/Contrast  (0x80/128  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Checkerboard  (0x80/128  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Vertical Lines  (0x80/128  '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Horizontal Lines  (0x80/128  '5'/53)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Judder  (0x80/128  '6'/54)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Color Bars@75  (0x80/128  '7'/55)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Color Bars@100  (0x80/128  '8'/56)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@10  (0x80/128  '9'/57)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@20  (0x80/128  '10'/49,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@30  (0x80/128  '11'/49,49)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@40  (0x80/128  '12'/49,50)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@50  (0x80/128  '13'/49,51)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@60  (0x80/128  '14'/49,52)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@70  (0x80/128  '15'/49,53)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@80  (0x80/128  '16'/49,54)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@90  (0x80/128  '17'/49,55)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@100  (0x80/128  '18'/49,56)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Gray Ramp  (0x80/128  '19'/49,57)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Coarse Cross Hatch  (0x80/128  '20'/50,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Fine Cross Hatch  (0x80/128  '21'/50,49)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Focus  (0x80/128  '22'/50,50)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HalfBW  (0x80/128  '23'/50,51)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC7B75  (0x80/128  '24'/50,52)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC7B10  (0x80/128  '25'/50,53)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC8s75  (0x80/128  '26'/50,54)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC8B10  (0x80/128  '27'/50,55)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = White@100  (0x80/128  '28'/50,56)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Red@100  (0x80/128  '29'/50,57)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Green@100  (0x80/128  '30'/51,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Blues@100  (0x80/128  '31'/51,49)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Cyan@100  (0x80/128  '32'/51,50)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Magenta@100  (0x80/128  '33'/51,51)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Yellow@100  (0x80/128  '34'/51,52)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Black@100  (0x80/128  '35'/51,53)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Off  (0xA5/165  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-1  (0xA5/165  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-2  (0xA5/165  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-3  (0xA5/165  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-4  (0xA5/165  '4'/52)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Reset to Factory Defaults = Execute  (0xAC/172  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Reset Input Name = Execute  (0x29/41  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Reset Picture Controls = Execute  (0x2B/43  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Reset Output Format = Execute  (0x2C/44  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Output Preference = Auto  (0xBA/186  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Output Preference = HDMI-A/V  (0xBA/186  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Output Preference = HDMI-A only  (0xBA/186  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Output Preference = Toslink  (0xBA/186  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Game Mode = Off  (0x2D/45  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Game Mode = On  (0x2D/45  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command 1:1 Frame Rate = Off  (0x2F/47  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command 1:1 Frame Rate = On  (0x2F/47  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = 16x9-FF  (0x30/48  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = 4x3-FF  (0x30/48  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = 4x3-LB  (0x30/48  '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = Panorama  (0x30/48  '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command PReP Mode = Auto  (0xB6/182  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command PReP Mode = Off  (0xB6/182  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Hot Plug Source = Auto  (0x71/113  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Hot Plug Source = Off  (0x71/113  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command De-Interlacer Bias = Auto  (0x49/73  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command De-Interlacer Bias = Film  (0x49/73  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command De-Interlacer Bias = Video  (0x49/73  '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Output Frame Lock = Auto  (0x74/116  '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Frame Lock = Unlock  (0x74/116  '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
post #6746 of 7061
Thanks so much for that info. How do I program those codes to a remote, though. Is there such a thing as an IR receiver *and* "sender" that I can plug into my laptop via USB?
post #6747 of 7061
Barry Gordon's IRGen (linked above, too)
USB-UIRT
post #6748 of 7061
I have a few questions for you guys...
Just had the Edge I bought s/h from Liechtenstein flashed to the latest firmware and now trying to replace my VP50 (which was constantly giving black screens on 24p).
Well, that worked OK on the Edge with 1:1 setting.
But:
1) Am I correct there's no contrast, brightness etc. hex code that allows me to change a setting without going through the menu?
Actually, I don't know how the handle these -50...+50 options shown in the wonderful IR Generator proggie; no up or down to press so what's the use?
2) Vert/hor stretch, same story; The VP50 allowed me to save 10 settings for pan/zoom combinations.
Could not find any of these...
post #6749 of 7061
But:
in answer to no.2 I'm pretty sure there are no memory functions for pan/zoom
which was probably the most convenient function on my VP50. I'm currently trying to find out if the Edge green can do it for me
Barry
post #6750 of 7061
Loved my original Edge. Power supply went out last night (Merry Christmas!?!)
Not sure whether to replace with Edge Green, Duo or some kind of Radiance product.
Kind of excited to have a reason to buy some new gear actually...
  Back to Forum: Video Processors
AVS › AVS Forum › Video Components › Video Processors ›  DVDO EDGE !!
