Originally Posted by
dlm10541
The problem is there is no one pattern. You need a number of them. Then you are not adjusting the EDGE but your display.
Use one of the available calibration disks to fine tune your display. You then use the EDGE to tweek each input to your liking.
Interestingly if we take 10 people on this thread who only want the one additional feature to make them happy and add them then the EDGE becomes a VPxx and no longer costs $799.
I agree. I think people might be underestimating the amount of complexity and work that would need to go into built-in test patters. What patterns? Just a "simple" 1:1 pixel mapping/overscan test pattern would need to work at: at least 1080p60, 1080p24, 1080i60, 720p60, and if I understand the "auto resolution by device preferred EDID" feature, then also at arbitrary resolutions and frame rates. Not simple to get that exactly right. Then you get into any color based patterns - YCbCr 4:2:2, YCbCr 4:4:4, RGB 4:4:4, etc would be needed, because you don't know what the display might or might not accept depending on the EDID it sends. I have found that while VP built-in test patterns are useful to me, they are not essential as you need calibration disks anyway to see the whole video chain.
