Originally Posted by
A9A1C1
Known issue with syncing to a DVI TV? I have a Hitachi tv at home and it says the source is not HDCP capable. Any ways to make it work? Thanks Andrew
well, hold on a minute: is this even an edge issue?
does your *source* (you don't say what yours is) do HDCP sync *without* the edge in the chain?
as DVDO points out in their FAQ (
http://www.anchorbaytech.com/dvdo_edge/support.php ) "Note that if you have an HDCP source and a non-HDCP display, you will probably not get a picture, whether or not you use EDGE."
you may still have to resort to an "HDCP stripper" "naughty box", whatever you want to call it, i realize, but let's make sure this actually involves the edge.
i say this because i experienced the same thing earlier this week with a DVI blade in the new 11th gen panasonic pro plasma. at first i started asking edge people for help, but then i went back and did the trivial test: can my source (a cable STB) talk to this blade with no edge in the middle? turns out it could not.
