AVS › AVS Forum › Video Components › Video Processors › New DVDO EDGE !!
New DVDO EDGE !! - Page 2
post #31 of 6974
I wish I had seen this before I bought my new AVR. But I'm still interested.
When can we expect to be able to purchase one?
post #32 of 6974
DVDO, AVS for starters...
post #33 of 6974
Would definitely consider this for my 1080p fixed pixel displays. Is beta testing restricted to US only or can we in Australia join too?
EDIT- Nevermind, found the sticky.
What cosmetic/hardware differences are there in the beta and production models?
post #34 of 6974
Will this product have the ability to turn off Progressive Cadence Detection for lower latency gaming with progressive-source game consoles?
post #35 of 6974
Originally Posted by Josh@dvdo View Post
EDGE is capable of detecting the "preferred" format that is reported by a display in its EDID. If that "preferred" format is not one of the default formats supported by EDGE (480p, 576p, 720p, 1080i, 1080p, or VGA) it can still be selected using the 'Auto' Output Format selection option. So if you have a 1920x1200 display that reports that 1920x1080 is the "preferred" format (which most PC monitors do) you will be able to output this resolution from your EDGE. If your display is a 1366x768 LCD that reports that its "preferred" format is 720p you will not be able to output the native resolution of this display.
There is no custom output timing option, like the VP30/VP50/VP50PRO have, on EDGE.
Thanks for clarifying this Josh. Incredible value regardless. Would you consider adding 1366 resolutions? Is it even possible at this stage? It will be a mute issue when I finally pull the trigger on a native 1080p set, but until then it sure would be nice to have a 1366 preset if custom resolutions aren't possible.
Can't see a sales related reason to omit it--is this a technical issue? (thanks in advance for expanding upon your original statement--if you can)
post #36 of 6974
Custom timings and resolutions...I could be way off on this but I'm betting that somewhere down the road firmwares could enable those features.
From where I sit, it's obvious that this thing is VP50 Jr. with some nice twists that even those units don't have.
I'm stunned at how robust the features are given this price point in contrast with those 50 series units. This thing's really close!
Clearly a giant killer in the makings.
My best guess is that when the final Edge streets we'll see price drops on the other DVDO units and firmwares and nice things like that.
It's really amazing how "close" to the 50 series these things are, at least according to Josh's opening post with the planned specs. I'd have to believe that the 50's would see a price drop right away when the final Edge streets.
post #37 of 6974
I guess this news kills 90% of Gefen Realta sales... (it should, at least!)
post #38 of 6974
The Gefen is still nice for us plasma owners. $100 cheaper too. Realta's no slouch.
If this DVDO offered 1360x768, 1365x768 and 1366x768 scaling, I wouldn't think twice.
post #39 of 6974
I think it stalls sales for everyone, including DVDO themselves.
Again, specs can always change, but as best I can see...this Edge is purported to have a LOT of the same features that the far more expensive 50 series units have.
I'm thrilled about this in general because quite frankly, this market has been WAY overdue for an outright giant killer to finally shake things up.
I bet it'll see firmware down the road that'll enable those features.
post #40 of 6974
Will the DVDO upgrade program apply to the Edge? I JUST ordered a VP50 and I'd like to know that if the general consensus once this is released is that it outclasses the VP50 in critical areas that I could upgrade if I choose. Or would this be a downgrade? Eh, I'm kinda new to this stuff.
I'm expecting to be in home theater heaven when my VP50 comes though, so maybe I'll forget all about the Edge...
post #41 of 6974
Keep in mind that this is a fixed chip design so features can not be added later--only bug fixes as Josh said.
The value of the VP series and other higher priced processors on the market lies in the range of customization and control that is possible. Some need this capability.
However many do not and this product is for them.
post #42 of 6974
This is why I'll be praying they add plasma resolutons before release.
post #43 of 6974
IMO, the constantly changing release date of the Gefen Realta did that already.
post #44 of 6974
When will some company other than Lumagen offer advanced gamut and gamma controls?
post #45 of 6974
I got a feeling its coming to the Pro...
post #46 of 6974
so this one is probably not for anyone using a 1024x768 pdp, correct?
post #47 of 6974
The advantage that you have is that the vp50
(and pro) is available NOW. Who knows when this will be available other than to beta testers. I loved my VP50 except except for the fact that it sucked passing the newer audio codecs. Video wise it was great!
Good luck!
Chris
post #48 of 6974
Originally Posted by Paul Butler View Post
Any possibility that the Edge could be upgraded with Test Patterns and Color Management adjustments in the future (I see there is a Service Port on the back)?
I think that these are the only things stopping this from being an absolute killer product (at present its just a killer!)
Paul
EDGE is not intended to be a technology platform like our VP line products. We have no intention of adding Color Management to EDGE before it goes to production (or after it is in production).
post #49 of 6974
the beta tester thread referred me to here, then here must go back to the sticky? so...infinite loop ?!
post #50 of 6974
Originally Posted by shamus View Post
Josh, will it have the ability to output a zoomed out 2.35 image and than instantly shrink it for 16x9 material like the 50 can?
I am not quite sure what you mean by this. What is the application?
post #51 of 6974
The Beta Tester thread refers you to this thread if you would like more information about EDGE. If you would like to submit the questionnaire to be a Public Beta tester you must go to: www.dvdo.com/edge
post #52 of 6974
Sorry Josh... its hard to explain.
I have a 2.35 screen and zoom out a 2.35 image to fit it. I set display to 16x9 and screen to 2.35. I now just simply set the input aspect ratio to whatever setting the movie is and everything fits perfectly on my screen without the use of a lens.
post #53 of 6974
I really doubt this is going to happen because these signal types are not video standards like 1080p, 1080i, 720p, etc.
The required signal timings for 1366x768 (for example) vary *a lot* between display manufacturers -- there is no one "1366x768 signal" that will work for everyone. (I made this mistake when I bought a VP20; it *looked* like it had the preset resolution I needed, but it didn't work with my display at all.)
By sticking to just the standard signal types, DVDO avoids this can of worms entirely.
post #54 of 6974
So I don't derail the VP50 pro thread:
Originally Posted by Gary Murrell View Post
why don't people wait and see a Edge before they try and compare it to the VP50pro
-Gary
Specs can always change but it's obvious the Edge is being set up as a giant killer and if you've looked carefully at Josh's opening post in that Edge thread, it has to stun you how many of the features from the 50's are set to be in this Edge unit for a fraction of the price.
I think Gary J. is dead on. I bet when the final Edge streets, we see price drops on the other units, for starters.
http://www.avsforum.com/avs-vb/showthread.php?t=1051294
You sign up for the Beta yet?
The response:
again pure speculation Q
BTW this is the VP50pro thread guys
-Gary
http://www.avsforum.com/avs-vb/showthread.php?t=1051246
Read Josh's post that opens this very thread up. How much of that is "speculation?" How much of my previous post is just "speculation?"
Please be as specific as you can. Direct quotes would be ideal.
The facts couldn't be more clear: That product, those specs, at a list of $800 is a giant killer.
It's enough of a giant killer that I can't imagine that DVDO doesn't consider a price drop on some of their other products when Edge hits the streets in a few months or whenever it is. Compare the specs that Josh cites in the first post here vs. those of the VP50 and VP50 Pro and then think about the huge price differences between those vs. the Edge.
Something's got to give.
Typically with electronics: They go down in price as times goes by anyways.
post #55 of 6974
Thanks for that, I wasn't aware they differed. Now I know why the Gefen has 2 different 1366x768 and others too.
post #56 of 6974
The response:
I am sure Josh will address your concerns, I am not at liberty to nor can I answer for DVDO's intention or plans
but on the other hand I am sure Josh will tell you that the Edge is not to replace the VP50pro, nor would it be a giant killer of their own product, the VP50pro is in fact a giant , it remains to be seen publicly how the Edge stacks up in a multitude of areas that specs don't always explain
-Gary
post #57 of 6974
*quietly slips briefcase under table*
You sure?
Of course not! I certainly wasn't suggesting that!
... nor would it be a giant killer of their own product, the VP50pro is in fact a giant , it remains to be seen publicly how the Edge stacks up in a multitude of areas that specs don't always explain
-Gary
Agreed.
Somewhere in my previous post perhaps I should have been more specific, like: "The Edge is poised to potentially be a giant killer."
Better?
post #58 of 6974
Hothersale is exactly right.
There are no standards for 1366x768 (or 1360x768). In our VP line products we have 4 presets to handle these resolutions and the user may be forced to change sync polarity or horizontally/vertically shift the image to get 1:1. Most users do not want to go through this kind of advanced setup and these displays are becoming less and less popular.
post #59 of 6974
This can be accomplished using the input aspect ratio of EDGE but it is not as easy as it is on the VP50PRO which has specific features (Output Aspect Ratio controls for Display and Screen) which EDGE does not.
post #60 of 6974
You won't get 1:1 pixel mapping, so your display will be applying its own scaling on top of the EDGE's. But you still do benefit from what is probably the best deinterlacing in the world, as well as the MNR, cadence detection, etc. of the EDGE.
--Andre
  Back to Forum: Video Processors
