AVS › AVS Forum › Video Components › Video Processors › New DVDO EDGE !!
New DVDO EDGE !! - Page 12
post #331 of 6977
Originally Posted by Pia-chan View Post
Josh explained in a previous post that the EDGE set to auto will output the 'preferred' format as communicated by the TV. Speaking for those of us with native 768p TVs, I'm interested in what our TVs will be telling the EDGE to send: 720p or 768p. I agree with you that the EDGE will be of great value even if it isn't actually capable of sending the native format in this case.
I think Josh's post was misleading. I THINK the Edge will output the preferred format when set to AUTO but only one of the half dozen preset output resolutions, and 768p is not one of them.
post #332 of 6977
Is there any point to attaching one of these to a 1080i-only RPTV (component-only, no HDMI), to scale output from my DirectTV HR21 DVR and my DVD player? Or am I better off letting the DVR do the scaling until I eventually upgrade my set to something more current that does 1080p?
I'm guessing no point, since I'm not seeing any component out on the i/o panel in the opening shots.
post #333 of 6977
Originally Posted by Gary J View Post
Have you tried a Panasonic thread? Your question is really about the TV, not the Edge, correct?
Actually, my original question was more about the EDGE because it isn't clear to me how flexible it is when set to "auto" format. Specifically, would the EDGE output 'non-standard' resolutions such as 1024x768, 1365x768, 1366x768, 1920x1200, etc., or is it actually locked into 'standard' resolution output only.
post #334 of 6977
Per previous posts the Edge will only output the listed standard resolutions.
post #335 of 6977
Originally Posted by Josh@dvdo View Post
EDGE is capable of detecting the "preferred" format that is reported by a display in its EDID. If that "preferred" format is not one of the default formats supported by EDGE (480p, 576p, 720p, 1080i, 1080p, or VGA) it can still be selected using the 'Auto' Output Format selection option. So if you have a 1920x1200 display that reports that 1920x1200 is the "preferred" format (which most PC monitors do) you will be able to output this resolution from your EDGE. If your display is a 1366x768 LCD that reports that its "preferred" format is 720p you will not be able to output the native resolution of this display.
Call me crazy, but I read this as meaning that the EDGE can output 1920x1200, which is 'non-standard'
post #336 of 6977
I am confused now too-easy to do
This seems to say a non-standard resolution can be output as long as its reported as the preferred resolution of the display.
I too would like clarification
post #337 of 6977
I think what you are missing is that a 1920x1200 (WUXGA) display is designed as a computer monitor. Every computer monitor that I have connected EDGE to has the correct timing descriptors for the preferred output format which EDGE can output when in the 'Auto' Output Format mode.
post #338 of 6977
+2
post #339 of 6977
What EDGE can output above and beyond the default output formats is determined by the display. If the display's preferred timing is not one of the default output formats, EDGE can still output this timing, given that all of the proper timing descriptors are included.
post #340 of 6977
Ok so what you need to know is if your TV has all of the proper timing descriptors. Good luck with that one.
post #341 of 6977
Thanks Josh
I think I understand now.
post #342 of 6977
Soooo...if our displays don't communicate this properly (768) would something like a DVI doctor successfully bridge this gap? Or does a DVI doctor rely on the same timing info being "broadcast"? If anyone knows...
post #343 of 6977
What is important is if your display reports the correct preferred timing that will in turn give you 1:1 pixel mapping, preferrably at the native resolution.
post #344 of 6977
Thanks for the clarification Josh.
Would the use of an HDMI to DVI adapter compromise what the display reports to the Edge?
Is anyone with a 1366x768 Panny Pro getting a Beta Unit?
post #345 of 6977
i am interested in getting on the list of potential customers to buy this unit from beta testers if they don't want it. how can i go about doing this? it would be a disservice to all if i were a tester as i have little time. thanks.
post #346 of 6977
Sadly for us in Europe, you'd have to use a DVI EDID emulator to report the right 1366x768 timings then feed the signal into a HDFury or similar in order to get native res @ 50Hz into a commercial Panny (short of a PF9 or PF10) via VGA
So Josh; sorry if this is repeating things ad nauseum but... on my vp50 I don't have to use any Display Profile* in order to achieve this;
HDMI1 input (SkyHD):
576p (PREP on) output at 1080p/50
1080i/50 (PREP irrelevant) also output at 1080p/50
HDMI2 input (DVD):
480p (PREP on) output at 1080p/24
576p (PREP on) output at 1080p/50.
HDMI3 input (HD DVD):
1080i/60 output at 1080p/24
You're saying that the EDGE won't be able to do that and I'd have to manually switch between the 2 principal output resolutions that I use? Albeit with discretes.
* As far as I can see, the only reason, with a single display, to use Display Profiles is if for a single input/res/freq combination you sometimes want to output a different frequency (only example I can think of is if you watch R1 video based DVDs from TV shows where you want 60Hz output instead of 24)
post #347 of 6977
Some noob questions:
1. Most of the content I watch these days is 1080p film or video content on bluray/PS3. Would DVDO provide any benefit to 1080p content like this (my projector does support 24 and 60 source content with a refresh rate 48, 60, etc)? Since there is no deinterlacing, scaling, or frame rate conversion required, is there any added benefit? (Other than the per-input image adjustments)
2. For standard DVD content, would I need to use a player that supports 480i out to get maximum benefit (such as one of the Oppos)? Or does PReP feature mean that dvd content that is dinterlaced by the PS3 can be re-interlaced then de-interlaced by the Edge, obviating the need for a player that supports 480i out? In other words, is there a way to get 1080p/24 from a dvd from the PS3 with the Edge doing all the scaling, deinterlacing, etc.?
Thank you!
Armando
post #348 of 6977
Correct, that's what PReP is for. The only time it wouldn't work is if the PS3 was applying some sort of filtering to the output so that the original 240 lines in each field were altered before being sent in the 480p frame.
post #349 of 6977
Yes
post #350 of 6977
Any chance of getting a AVS group purchase price?
post #351 of 6977
hey guys, is this better than the VintageHD running on HQV Realta chip? A friend of mine who own this claimed that it's making full use of the HQV Realta features.....
and on the other hand.....another friend kept discouraging me from even joining the beta test, coz there is a limit for SD->HD no matter how you scale
post #352 of 6977
What is the return policy for a beta tester on the EDGE if not satisfied with how the unit performs or works with our equipment?
Mr Ian B
post #353 of 6977
I am somewhat unclear on the audio input assignability. Can you double up?
For instance, if I have an inday component switch feeding component #1, can I route 2 opticals, 1 coaxial and 1 stereo pair all to component #1? (component #2 will be taken with RGBHV). I am trying to decide between the Zektor and the Inday, and it seems there is lower loss with the Inday but no audio capabilities. That won't matter if I can perform the above...
edit: only 1 audio source would be live at a time--or perhaps there could be a priority set in the case of multiple signals present?
post #354 of 6977
HDMI2 input (DVD):
PLEASE can we have a definitive answer to this.
A related question: When a output is selected, does one select a resolution (e.g. 1080p) or resolution and frequency (e.g. 1080p24)?
Edit: What would happen with a European PS3 which can output 576p50 (for DVD), 1080p24 (for Blu-Ray), and 1080p60 (for games)?
post #355 of 6977
True
but how close to the limit would you like to get?
Having seen dodgy deinterlacing plenty of times and the horrendous ringing you get on (for example) the Panasonic PZ80 when scaling even 720p to 1080p, I'd say £400 is money well spent if this even comes close to the performance of the VP50Pro.
post #356 of 6977
Originally Posted by stepmback View Post
But with that said the VP is capable of accepting a 1080p signal and downconverting it to 1080i?
Unless you've got a CRT based display that can handle 1080i well, I'm not sure why you would want to do this? Would it not be better to use (say) 720p if it's a plasma or LCD?
post #357 of 6977
Mr Ian B
Read the NDA you signed (if you signed it). It clearly tells you this info.
post #358 of 6977
It would be nice if the question could be answered for others who are on the fence about applying, though...
post #359 of 6977
I overlooked it in the form. It says, "By signing this agreement, the User understands that there are no rights to return the product for a full refund."
Mr Ian B
post #360 of 6977
Guess what I have? But only until I ship them out...
Yup...DVDO Edge units...I will start forwarding tracking this evening for those who I have already contacted.
(If you have not been contacted yet hold tight...I'm-a-workin'-on-it. ).
  Back to Forum: Video Processors
