AVS › AVS Forum › Video Components › Video Processors › New DVDO EDGE !!
New DVDO EDGE !! - Page 130
post #3871 of 6974
I wonder if I can leave the USB cable permanently in there after, not connected to anything? Won't cause any interruptions to the unit?
i do... wired a short one i had lying around right into my rack... all i do now is set my macbook down on the top shelf, pull up the cable from the back, plug in, and away we go...
the bigger pita is pushing in the reset button...
post #3872 of 6974
Just got my Edge and set it up tonight. Haven't had a lot of time to play with it, but I did run into one issue that I think I was able to resolve.
When hitting an activity with my Harmony, the Edge would not turn on. The red light would come on, but that's it. Every time I would hit power, the red light would flash green, but that's it. I'd turn it off and then back on, but it would never actually turn on - just the constant red light with a flash of green whenever I hit the power on button.
I turned the Edge off and turned off my TV. Then I turned the Edge on and the red light came on. Then I turned on my TV and the Edge fired right up. In my Harmony, it was sending the command to turn the Edge on last (didn't think it mattered) and it won't turn fully on if the TV is already on. I changed the order in my Harmony so that the Edge powers on first and have had no issues.
Why would this be?
Spent a couple of frustrating hours trying to figure this out and I guess it doesn't matter for now, but still curious as to why it has to be turned on first.
post #3873 of 6974
Originally Posted by mdputnam View Post
You're not the only one Look here and here
Haha those are actually my threads, trying to crack the riddle. Having googled myself, I could not find any information. My best guess so far the Wii is outputting RGB with sync on green.
post #3874 of 6974
It would probably cost extra to have a console output YCbCr, I believe a console's graphics chip(s) have always natively output RGB, which was then combined to composite or Y/C, etc. going all the way back to the 8-bit days.
The PS3 also outputs RGB when playing games and when showing the console menu, IIRC.
post #3875 of 6974
Originally Posted by jd213 View Post
I believe a console's graphics chip(s) have always natively output RGB...
That's my thought as well. I would have been surprised if I saw that my Wii was outputting YPbPr.
That is correct.
post #3876 of 6974
I didn't know all that. Actually a PAL N64 does not output RGB. The graphics chip converts it (internally) to S-Video or composite. Therefor, PAL N64's cannot be RGB modded unlike their NSTC couterparts.
So, just to be clear, the Wii outputs RGB with sync on green? And the EDGE supports this?
I am still wondering why EDGE requires the red stereo phono to be connected directly too. If I run the audio through a switch box the picture blinks on and off. When I put the red phono into EDGE directly I get a picture.
post #3877 of 6974
Why would this be?
i'm fortunate that i don't have sequencing issues, but i know some have...
what do you have the "auto on" option set to in the edge?
does it happen regardless of the source (i.e. dvd/cable/bluray, etc.)?
post #3878 of 6974
The "auto on" is currently set up to whatever the default is, since I haven't changed any settings yet.
I'm pretty sure it happens regardless of source, because the display seems to be the key. Hooked up to the Edge are TWO Directv DVR's which are always on and a PS3 (and a VCR that's never used). Whether I hit "Watch DVR1", "Watch DVR2", or "Watch movie", the Edge would not turn on unless it was first.
Additionally, when I switch inputs on the Edge via the Edge remote (i.e. go from HDMI1 to HDMI2), it switches seamlessly. When I switch activities with my Harmony (i.e. "Watch DVR1" to "Watch DVR2"), which should be basically doing the exact same thing, there's a momentary blue screen that flashes up.
post #3879 of 6974
Why would this be?
Are you using the IR jack at the back of the unit? Because when I used mine I found it was causing very similar issues. I had to use ir emitters and it was working fine.
post #3880 of 6974
Just wanted to ask are some of you expericing audio dropouts? I've got the audio coming out from the edge seperatley to the amp and have noticed at times audio drop outs.
post #3881 of 6974
If it is the Edge( Have to admit never had this problem before especially with the movie I played Master and Commander Blu ray) well then hopefully this upcoming firmware fixes the issue.
post #3882 of 6974
Why would this be?
I turn my Edge on first also. It seems to operate on the same principle as computer equipment. If things are out of sequence with computer stuff, the computer may not recognize the device. It must be able to "read" it. If I switch inputs on the TV and then back that often solves the problem.
But Edge first then TV works every time.
post #3883 of 6974
No.
post #3884 of 6974
I have a question about updating the firmware on a Mac. Instead of dragging the new firmware to the EDGE (PC way) you double click an updater icon and the new firmware is installed automatically and the EDGE is unmounted automatically.
How do you backup the old firmware? Open the EDGE icon in finder and drag it to the desktop? Reverse if I needed to revert to the old firmware?
post #3885 of 6974
My first real problem with the Edge. I turned it on tonight, and all I get is the red light. I double-checked my connections and the power cord is plugged in securely; I haven't touched anything. I tried rebooting by disconnecting and reconnecting the power cord; still only the red light, which now goes out after a few seconds or so. Does anyone know what's happening? I'll dig out the manual in the meantime, but I hope someone has some ideas on this.
post #3886 of 6974
Yep, I get them occasionally and have programed a button on my universal remote called "fix" which power-cycles the EDGE and fixes the problem.
post #3887 of 6974
Thanks djos you have been a great help once you power cycle the unit how long before you get another issue? I hope this new upcoming firmware addresses the problem.
post #3888 of 6974
Originally Posted by jedi.master.dre View Post
Here is what Larry from DVDO told me today:
"We are days away from a public release of v1.2. I suggest getting the public version from our website; it should be posted next week. It is definitely recommended because of its improved compatibility with other components and some nice new features."
Sweeeet!
I can also confirm the upcoming release of v1.2 in just a matter of days. This coming Monday (4/13) I am sending my unit back to DVDO for replacement and they assured me the new unit shipping out will have firmware v1.2. I have no idea what the other new features will be but am looking forward to them nonetheless. On a whim I asked if the Edge might now be able to pass through DSD bitstream audio signals and they said that is still not possible.
post #3889 of 6974
No probs.
Mine is usually good for a couple of days after that but it is a bit random - also, I never turn my edge off as my Media Center/Server has a fit if I do.
post #3890 of 6974
Is your display on? Do you have an input on?
post #3891 of 6974
I also get audio dropouts.. seemingly randomly, but it's probably once every few days. At first I thought it was my Motorola HD DVR, since that would happen if I quickskipped many times in a row, then I would mute and unmute. I wonder if there's a discrete remote command for the Edge where you can just tell it to turn audio off/on instead of power cycle? Or maybe just switch to a different audio output, then back again.
In any case, I also hope they get this fixed in a future firmware update. This doesn't happen when we're doing anything, like changing source material, channels, etc.
post #3892 of 6974
I seem to have resolved the problem, though it bears watching. Apparently it was set to an input other than the one I was trying to view; I didn't remember not switching from BD back to cable (an always on input) the last time out. Thanks.
post #3893 of 6974
Not sure if this has been reported or not but there have been 2 instances of where when I'm watching SD programming (rare these days) I'll suddenly get snow, as if the cable has been disconnected from my TV, except this snow has color, instead of just black and white. Has this happened to anyone else? Changing inputs cured this. Wish I could somehow screencap to better illustrate the problem. I'm still on V1 firmware as the 1.1 update didn't work for me.
post #3894 of 6974
I was testing my Harmony remote and had this happen:
Power off the EDGE while everything else was left on, then powered EDGE back on only the TV keep reporting 'No Signal'. I tried switching inputs on the EDGE and then the TV. Next I tried cycling the power on the DVD player, but nothing again. Next I power cycled the TV with no results. I finally got a signal back by powering every down and waiting for the red led on the EDGE to go out and restarting everything (via the Harmony remote).
Is there something special needed to be done to power cycle the EDGE once in use?
post #3895 of 6974
I like to thank Larry Thompson from DVDO for suppling me with the firmware 1.2. Hopefully this addresses the Audio dropouts. I also like to thank MarkH from sound advice who exchanged my unit as it did not work during the upgrade prurpose.
post #3896 of 6974
Im glad I bought through MarkH too as there certainly have been a number of DOA Edge's out there and it's nice to know Aussie support is but a phone call away.
post #3897 of 6974
What is the new upcoming firmware after 1.2? If my audio dropouts get sorted im certainly not going to jump to it.
post #3898 of 6974
No Idea, maybe a DVDO rep can answer?
post #3899 of 6974
1.2 is the new one. I went to go and check.
post #3900 of 6974
v1.2 isn't on the DVDO website yet.
  Back to Forum: Video Processors
