Hey all
I love my DVDO Edge but I think the menu system is a bit unwieldy, lots of button clicks to get into the Advanced Settings submenu to change anything useful. So I was happy to learn that almost all of the Edge's functions can be controlled by discrete remote codes. These can be programmed directly if you have a Pronto-compatible remote, or if you have a Harmony then you can email Logitech and get them to add the codes to your profile (you can add them yourself but it's a pain).
It seems these were readily available on the old forums but I had trouble getting hold of them when I looked recently. In the end I found Barry Gordon's excellent DVDO IR Generation program which is still available on his
website and generated all or almost all of the codes for the Edge (new discrete codes may have been introduced in recent firmware, I'm not sure). But in case anyone doesn't have Windows I thought I'd list all the codes here as actual text rather than a link to an offsite file that might disappear.
Hope they're useful to someone. I've been getting a lot of use out of the discrete output modes, turning the 1:1 frame lock on and off, and switching the HDMI audio output between audio-video and audio-only output, which has the effect of routing audio straight through to my TV or through the amplifier.
Code:
IR Data For Command Video Input Select = Auto (0x4C/76 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = Video (0x4C/76 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = S-Video (0x4C/76 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = Component1 (0x4C/76 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Video Input Select = Component2/PC (0x4C/76 '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-1 (0x4C/76 '5'/53)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-2 (0x4C/76 '6'/54)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-3 (0x4C/76 '7'/55)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-4 (0x4C/76 '8'/56)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-5 (0x4C/76 '9'/57)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Video Input Select = HDMI-Front (0x4C/76 '10'/49,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Video Input Select = Off (0x4D/77 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Auto Video Input Select = On (0x4D/77 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Brightness(0x21/33) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Brightness(0x21/33) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Brightness(0x21/33) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Contrast(0x22/34) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Contrast(0x22/34) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Contrast(0x22/34) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Saturation(0x23/35) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Saturation(0x23/35) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Saturation(0x23/35) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Hue(0x24/36) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Hue(0x24/36) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Hue(0x24/36) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Fine Detail(0xC8/200) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Fine Detail(0xC8/200) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Fine Detail(0xC8/200) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Edge Enhancement(0xC9/201) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Edge Enhancement(0xC9/201) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Edge Enhancement(0xC9/201) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = Off (0xCA/202 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = Low (0xCA/202 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = Medium (0xCA/202 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Mosquito NR Control = High (0xCA/202 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command YC Delay(0x27/39) Minimum of Range=-50
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command YC Delay(0x27/39) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command YC Delay(0x27/39) Maximum of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Horizontal Zoom(0x40/64) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Horizontal Zoom(0x40/64) Middle of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Horizontal Zoom(0x40/64) Maximum of Range=100.0
0000 006C 003B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Vertical Zoom(0x41/65) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Vertical Zoom(0x41/65) Middle of Range=50
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Vertical Zoom(0x41/65) Maximum of Range=100.0
0000 006C 003B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Horizontal Pan(0x42/66) Minimum of Range=-240
0000 006C 0033 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Horizontal Pan(0x42/66) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Horizontal Pan(0x42/66) Maximum of Range=240
0000 006C 002B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Vertical Pan(0x43/67) Minimum of Range=-240
0000 006C 0033 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Vertical Pan(0x43/67) Middle of Range=0
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Vertical Pan(0x43/67) Maximum of Range=240
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Overscan(0x46/70) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Overscan(0x46/70) Middle of Range=50
0000 006C 0023 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Overscan(0x46/70) Maximum of Range=100.0
0000 006C 003B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = HDMI (0x4A/74 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Coaxial (0x4A/74 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Toslink-1 (0x4A/74 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Toslink-2 (0x4A/74 '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Toslink-3 (0x4A/74 '5'/53)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Input Select = Stereo (0x4A/74 '6'/54)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Delay(0x4B/75) Minimum of Range=-56
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Delay(0x4B/75) Middle of Range=72
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Delay(0x4B/75) Maximum of Range=200
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = Auto (0x61/97 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 480i (0x61/97 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 576i (0x61/97 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 480p (0x61/97 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 576p (0x61/97 '4'/52)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 720p50 (0x61/97 '5'/53)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 720p60 (0x61/97 '6'/54)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080i50 (0x61/97 '7'/55)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080i60 (0x61/97 '8'/56)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p24 (0x61/97 '9'/57)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p25 (0x61/97 '10'/49,48)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p48 (0x61/97 '11'/49,49)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p50 (0x61/97 '12'/49,50)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = 1080p60 (0x61/97 '13'/49,51)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = VGA60 (0x61/97 '14'/49,52)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = SVGA60 (0x61/97 '15'/49,53)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = XGA60 (0x61/97 '16'/49,54)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Output Format Selection = SXGA60 (0x61/97 '17'/49,55)
0000 006C 0023 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Display Active Ratio = Auto (0x6A/106 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Display Active Ratio = 16x9 (0x6A/106 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Display Active Ratio = 4x3 (0x6A/106 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Underscan(0x8B/139) Minimum of Range=0.0
0000 006C 002B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Underscan(0x8B/139) Middle of Range=10
0000 006C 0023 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Underscan(0x8B/139) Maximum of Range=20.0
0000 006C 0033 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = Auto (0x6C/108 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = RGB (0x6C/108 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = YUV422 (0x6C/108 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Color Space {RGB/YUV} = YUV444 (0x6C/108 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Colorimetry {601/709} = Auto (0xE5/229 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Colorimetry {601/709} = 601 (0xE5/229 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Colorimetry {601/709} = 709 (0xE5/229 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Dynamic Range = Auto (0xE6/230 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Dynamic Range = Video (0xE6/230 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Output Dynamic Range = Computer (0xE6/230 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Input Dynamic Range = Auto (0xF0/240 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Input Dynamic Range = Video (0xF0/240 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Input Dynamic Range = Computer (0xF0/240 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0044 0044 0016 0001
IR Data For Command Power = Off (0xA1/161 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Power = On (0xA1/161 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Standby = Off (0x83/131 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Standby = On (0x83/131 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Auto Wake Up = Off (0x2E/46 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Auto Wake Up = Mode-1 (0x2E/46 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Auto Wake Up = Mode-2 (0x2E/46 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Off (0x80/128 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Frame Geometry (0x80/128 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Brightness/Contrast (0x80/128 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Checkerboard (0x80/128 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Vertical Lines (0x80/128 '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Horizontal Lines (0x80/128 '5'/53)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Judder (0x80/128 '6'/54)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Color Bars@75 (0x80/128 '7'/55)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Color Bars@100 (0x80/128 '8'/56)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@10 (0x80/128 '9'/57)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@20 (0x80/128 '10'/49,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@30 (0x80/128 '11'/49,49)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@40 (0x80/128 '12'/49,50)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@50 (0x80/128 '13'/49,51)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@60 (0x80/128 '14'/49,52)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@70 (0x80/128 '15'/49,53)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@80 (0x80/128 '16'/49,54)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@90 (0x80/128 '17'/49,55)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = IRE@100 (0x80/128 '18'/49,56)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Gray Ramp (0x80/128 '19'/49,57)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Coarse Cross Hatch (0x80/128 '20'/50,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Fine Cross Hatch (0x80/128 '21'/50,49)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Focus (0x80/128 '22'/50,50)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HalfBW (0x80/128 '23'/50,51)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC7B75 (0x80/128 '24'/50,52)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC7B10 (0x80/128 '25'/50,53)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC8s75 (0x80/128 '26'/50,54)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = HC8B10 (0x80/128 '27'/50,55)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = White@100 (0x80/128 '28'/50,56)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Red@100 (0x80/128 '29'/50,57)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Green@100 (0x80/128 '30'/51,48)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Blues@100 (0x80/128 '31'/51,49)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Cyan@100 (0x80/128 '32'/51,50)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Magenta@100 (0x80/128 '33'/51,51)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Yellow@100 (0x80/128 '34'/51,52)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Test Pattern Generation = Black@100 (0x80/128 '35'/51,53)
0000 006C 0023 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Off (0xA5/165 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-1 (0xA5/165 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-2 (0xA5/165 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-3 (0xA5/165 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Info Screen {OSD} = Page-4 (0xA5/165 '4'/52)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Reset to Factory Defaults = Execute (0xAC/172 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Reset Input Name = Execute (0x29/41 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Reset Picture Controls = Execute (0x2B/43 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Reset Output Format = Execute (0x2C/44 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Audio Output Preference = Auto (0xBA/186 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Output Preference = HDMI-A/V (0xBA/186 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Output Preference = HDMI-A only (0xBA/186 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Audio Output Preference = Toslink (0xBA/186 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Game Mode = Off (0x2D/45 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Game Mode = On (0x2D/45 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command 1:1 Frame Rate = Off (0x2F/47 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command 1:1 Frame Rate = On (0x2F/47 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = 16x9-FF (0x30/48 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = 4x3-FF (0x30/48 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = 4x3-LB (0x30/48 '3'/51)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Input Aspect Ratio = Panorama (0x30/48 '4'/52)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command PReP Mode = Auto (0xB6/182 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command PReP Mode = Off (0xB6/182 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0044 0044 0016 0001
IR Data For Command Hot Plug Source = Auto (0x71/113 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Hot Plug Source = Off (0x71/113 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command De-Interlacer Bias = Auto (0x49/73 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command De-Interlacer Bias = Film (0x49/73 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command De-Interlacer Bias = Video (0x49/73 '2'/50)
0000 006C 001B 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0044 0044 0016 0001
IR Data For Command Output Frame Lock = Auto (0x74/116 '0'/48)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
IR Data For Command Output Frame Lock = Unlock (0x74/116 '1'/49)
0000 006C 001B 0000 0064 0064 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0044 0044 0016 0001
