Originally Posted by T2k
Make sure you have NOT enabled frame locking and that your display DOES support 24p eg 48hz, 96Hz, 120Hz, 240Hz etc refresh rates. TBH if I were you I'd use 1080p60 as output for a 1080i60 source, not 1080p24.
That being said are you positive the source is OK? Have you ever seen your copy playing fine on anything? Are you sure your friend isn't watching it on some odd projector or something else?
Authoring in 1080i60 something and claiming to be the 'best quality release' sounds more than suspicious to me...
I'm sure I disabled frame locking when I set Edge output to be explicit 1080p24 or 1080p60.
The TV supports 24p from most Blurays just fine.
I initially used 1080p60 output on the Oppo direct to TV, which is what alerted me to an issue. I get the same issue when using the Edge to output 1080p60 from the Oppo.
I am not sure the source is okay. Authoring a movie in 1080i60 is dodgy at best and I'm surprised it was done this way for the Bluray. However, ignoring the display issue, the Japanese Bluray has DTS-HD MA audio and AVC video that has greater detail and shadow than the other Bluray editions. I suspect Sleepy Hollow was originally encoded for HD-DVD with substantial filtering and this re-tasked to most Bluray editions. The Japanese Bluray has obviously been handled differently.
Maybe I am just overly sensitive to 3:2 pulldown judder as I am used to smooth 50i from PAL land and now smooth 24p, so watching 1080p60 pulldown is something of a shock in comparison.
I was mainly curious why the Edge couldn't return a smooth 1080p24 as the source would have to be 3:2 pulldown encoded.
