Originally Posted by
crappy_htpc
I recently got a new motherboard with integrated Intel g35 and I am using its HDMI to connect to my 720p Samsung DLP. There seems to be a issue with the driver or could be there is some setting I am unaware of: whenever I changed sources on the TV from say from HDMI_1 to HDMI_2 (g35 is hooked up to HDMI_1), the g35 would change its resolution from 720p to 800x600, and when I switched back to HDMI_1, g35 resolution would stay at 800x600. The same occurs if I would to turn the TV OFF and ON again. It is quite annoying, any ideas?
Yes. This is a known issue with G35 systems.
there's two fixes.
1. Update Graphics Drivers to the latest. This was fixed in 15.8 but 15.9 will work better.
2. Disable the IGFXPERS process. This is where the bug was. DPlettner found this work around. You can permanently disable it by deleting the entry from the registry. The key can be found in HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVer sion \\Run
look for the "Persistence=C:\\Windows\\system32\\igfxpers.exe" entry and delete it.
Wo0zy
