AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official VSX-01TXH and VSX-03TXH Owners Thread
Official VSX-01TXH and VSX-03TXH Owners Thread - Page 79
post #2341 of 3242
Considering a 25 to 30 foot run of FLAT HDMI cable under carpeting to connect my Blu-ray/03 to the TV. Anyone have any opinions or ideas?
post #2342 of 3242
Monoprice sells Premium 24AWG Flat Type HDMI Cable with lengths up to 35 feet long. That would probably be your best bang for the buck.
For what it's worth I ran flat speaker wire under my wall to wall carpet from my AV receiver to my rear speakers and you can hardly see any bulge in the carpeting. The installer used one of those snakes for wiring the wall to push the flat speaker wire under my carpet's padding from one side of my living room to the other.
http://www.monoprice.com/products/su...02&cp_id=10240
post #2343 of 3242
I'm having a problem with VSX01, It's been setup for a few days working great now, when switch to my cable box to watch it, the picture and sound keeps dropping out for a second or two. THis happens every ten seconds. Does anyone know why it's doing this?? It just happend all of sudden.. I have a comcast HD cable box. Im using a HDMI cord for the connection to the receiver, and from the receiver to the TV>.
post #2344 of 3242
The HDMI connector in the '01 is rather flimsy. If the connection isn't made well there is a possibility of a momentary dropout. This gets amplified by an HDCP re-handshake and that could take a couple of seconds. Try re-inserting your cables and position them so they don't move. It took me a bit of frustrating jiggling to get it to connect and stay connected. A few others have had the same issue, corrected by a cable re-insert. Good luck.
post #2345 of 3242
Originally Posted by krizzz View Post
Hey Folks - I am trying to program my Harmony One to control my VSX-03 and I can seem to find the codes. Is there some kind of update I need to run on the Harmony software? I can't image Logitech wouldn't have the codes at this point... Any ideas??
BTW - I just updated the software and the remote firmware through the GUI and VSX-01/VSX-03 is still not there. They have a VSX-D3 (d, not 0), but this does not match the 03's functions...
I have a Harmony 550/VSX-01 combo & I had to get Logitech support to add the specific commands that were missing to my account. I'm not sure why they didn't just add the missing commands to the database for everyone, but they did get me access to the commands that I requested the next day. E-mail their support with a list of the commands that you want added and they should add them to your account.
post #2346 of 3242
He's not missing commands, he's missing the Receiver altogether.
Whenever I'm missing commands, I just learn them to the Harmony. Takes a lot less time than a phone call.
post #2347 of 3242
Thanks, yes, that's what I did, as well as, turn the cable box off and restart it.. It was just frustrating that everything worked great until today when I was trying to watch cable.. I was like WTF... Thanks again for your response..
post #2348 of 3242
Hi I am trying to locate either the VSX 01 or the 03, I seem to have found one place, but don't really know the seller's background - please PM me to help.
post #2349 of 3242
I just bought an 03 from a seller on Videogon. It was a brand new in box unit from a dealer for a great price
post #2350 of 3242
I recommend that you simply contact the regular sponsors on this forum and compare their prices.
post #2351 of 3242
I win the Darwin award... I entered VSX-03 and nothing came up. When I entered "VSX-03TXH" it worked perfectly...feeling pretty boneheaded right now.
post #2352 of 3242
Not your fault. Usually with computers, less is more. I might have done the same.
post #2353 of 3242
Am i doing something wrong? I have my Elite DV-48AV hookup up to my VSX 03 TXH throught an HDMI input and i can't figure out how to get my multichannel sacd's to play in 5.1 everything else works which includes my dvd audios through the same player, bd's on my ps3, and tv programing through direct tv. On the receiver display it only shows 2 speakers lit up no matter what setting i select with a sacd in the player. Thank for any advice you can give me.
post #2354 of 3242
Ooops, found my answer in cd player forum....and it sounds great!
post #2355 of 3242
just sent u a PM.
alan in cc,tx
post #2356 of 3242
Can anyone tell me how to use a spl meter with the 03 receiver? would I use the test tones from the receiver and what should be the setting, or can someone just post the link and I will try to follow, I am borrowing a meter from work and will like to use it this weekend..I did a google search and read many diffrent things, so if anyone can help me thanks in advance, MACFAN thanks for your help with my sub, maybe you can chime in on this?
ciccio
post #2357 of 3242
ciccio
Someone gave you a whole list of references in another thread. Briefly, though, if all you want to do is verify that MCACC balanced your system correctly, the receiver's test tones will be fine. The 03 will set them at the appropriate level, ~ 75dB.
There are lots of other things to play with, but most of them are covered in detail in references you were supplied. Many of them require using test tones from a different source, either a commercial disc or downloads, depending upon what you want to accomplish.
post #2358 of 3242
Hey guys, I spoke with "Will" over at Videogon. He says he's an authorized dealer. Does anyone have more information about him or his business? Is he reliable? Anyone with good or bad experiences dealing with him?
post #2359 of 3242
Will is top notch got my VSX-01 from him.
post #2360 of 3242
Torn between the HK 354 or the VSX 01...anyone have any recommendations? The HK 354 owners thread talks about many issues with it...
post #2361 of 3242
Thanks for the feedback on him! Anyone else with positive experiences?
post #2362 of 3242
Probably 25% of the people in this thread bought from Will. Do a search on videogon or Will and you'll find hundreds of posts. Yes, he's legit and is easy to work with.
edit: actually you can't search on Will, because it's too common of a word, but you get the idea.
post #2363 of 3242
So the Pioneer warranty will be valid and honored if we buy from him? I spoke to him today actually and he wants $550 with shipping for the 03.
post #2364 of 3242
Yes. He has a retail store.
post #2365 of 3242
I bought my 03 from Will about two weeks ago. Great service no complaints here. Would deal with him again anytime
post #2366 of 3242
What are the differences between the Elite 03 and 01? I looked at Pioneer's website and really couldn't see much of a difference.
post #2367 of 3242
I think the main difference is that 03 has jitter reduction. Will's cool.
post #2368 of 3242
I was one of the first to buy from him on Videogon. Nothing but good to say. They are an authorized dealer, but not an authorized internet dealer.
post #2369 of 3242
Technically, they aren't selling via the internet. Just advertising.
post #2370 of 3242
Ordered my VSX-01 through "Will" today. Was a little hesitant at first, asking him a whole bunch of questions that I'm pretty sure that he's heard hundreds of times before, like "why are you so cheap", "what's the warranty" etc.
ANyways, I ended up with the 01 because I didn't see the need for the extra stuff (like jitter reduction - what's that exactly?) on the 03 eventhough it's only slightly more. Can't wait to get it in and hook it up to my Quintet SLs.
