Originally Posted by unavol
DariRose,
Are you switching the input to the corrosponding HDMI1 or HDMI2 input after you plug the HDMI cable from your device as explained on p. 16 of the manual? The VSX-01 won't automatically switch to the proper HDMI input. It has to be done manually. For example, plug your satellite box's HDMI cable into the HDMI1 input on the VSX-01 and press the HDMI1 button on the front of the VSX-01 until the display shows HDMI1. Unless you have a defective unit or I am misunderstanding what you're trying to do I believe that process should get you a picture. Hope that helps.
DariRose,
Thanks UnaVol. I don't get a picture or sound, even after cycling through to the corresponding input(s). (I've tried both.) The res on my DirecTV box is set to 1080, so I'm not sure res is the issue. I sure hope the unit isn't defective....
