Originally Posted by
FIVE ONE SIX
you're right about that, but the sad fact is that most HDTV's that have VGA inputs don't really allow you to change that many picture settings when using that VGA input, at least not compared to the amount of picture changes that you can make with both component and HDMI. so while it should look better, sometimes it doesn't solely based on the fact that things that you would change to make it look better can't be changed...
and for me, video is via HDMI and audio is via Optical...
Most of the settings that are disabled for VGA (shapness, color, tint, etc) don't need to be adjusted using an RGB signal. They are automatically correct and any adjustments you do would hurt the picture, not help it.
The only controls (outside sync and stuff) VGA really needs are brightness and contrast. White balance and gamma would also be nice but they aren't essential.
