AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Magnavox tb100mw9 not saving config
post #1 of 2
I run the initial setup and if I turn the box into standby mode it loses the config. Do I have a defective unit or is there a way to save it ???? I thought it is supposed to save it once it goes through the available channels. Other than this it works fine and I am able to get all the channels needed.
post #2 of 2
Originally Posted by xaeniac View Post
Do I have a defective unit ... ????
It certainly sounds that way.  I have the MG9 rather than the MW9, but it saves the channel table and most of the selected options, even if disconnected from the AC power.
