AVS › AVS Forum › Audio › DIY Speakers and Subs › My sealed Maelstrom-X build...
post #1 of 161
I'd like to thank NEO-Dan for his cutsheet and design and Sherv for the motivation to get this project rolling, and anyone else who posts a lot in this section.
Here is the design I used (courtesy of Dan):
I had the worker at Lowes cut the sheet into three sections (the two sides off the end, and then down the middle) to make it easier to handle at home. He made accurate cuts. My dad and I cut the rest with a circular saw and guide.
Today we began the assembly.
The top of the middle brace is a bit fubar, but the other sides are good. The blade on the circular saw was bending a bit.
We countersunk all visible screws and then filled the holes with putty and sanded plenty. I wanted to go for a different color than the usual black and decided on a red wine color.
In the pictures below only the red primer has been applied. One can was enough for about 1 coat. We noticed the putty filled holes don't look perfect, so we're gonna work on those tomorrow before we put anymore primer on.
At first I will power this with my XS900 bridged...until I have put it through its paces. I might just buy another amp for my TC-2000 sub, like a used Ep2500.
post #2 of 161
Looking good Will
post #3 of 161
Thanks Dan!
post #4 of 161
Looks good! How did you cut out the driver hole?
post #5 of 161
Used my router and a jasper jig. To get the 18.5" cutout for the outer baffle I used the maximum setting on the jig and already had a 1/2" straight bit, so it came out to 18.5" exactly.
post #6 of 161
Nice box Will. The fun will start when you fire this baby up!
post #7 of 161
Ah, cool. Looks like a quality build, man. Wish I could find a friend with a router. Too bad HD doesn't rent them out. :\\
Good luck with finishing up the painting!
post #8 of 161
Is 0.75" MDF thick enough for a Maelstrom-X or would 1" MDF or plywood be a better idea? I just ordered my Maelstrom-X yesterday and I am looking to put it into a sealed box but I was under the impression that 0.75" MDF would just not cut it for a sub as serious as the Maelstrom-X. If NEO-Dan's sealed box will be strong enough than I will build that box. I had envisioned needing 1" thick sides with a 2" front and some more extensive bracing. If that is overkill then that would same me a lot of time and money getting the 1" plywood.
post #9 of 161
ABOUT DAMN TIME!
looking good willy! ...so what are you gonna use for EQing on it? are you going to do any L/T for it?
post #10 of 161
No doubt! Can't wait to listen tonight.
Thanks. Mine is just a Skil 1825 combo I got from skilshop refurbished for $65 shipped. It has 1/2" shank, variable speed, a light, and a cheap vacuum accessory that I haven't tried out yet. Down the road I'll probably get a better one and let this one go on craigslist.
Sherv says it is and he's built 4 of these cabinets. It feels solid enough to me. It is efficient with its use of wood with the two braces and the construction in general. I used titebond and plenty of screws so I feel good about it strength.
ABOUT DAMN TIME!
Thanks man. I don't have an EQ device yet but at the top of my list is a DEQ/DCX....and possibly a second Maelstrom down the road.
post #11 of 161
If it's properly braced and the baffled is doubled up there should be no problems.
post #12 of 161
Are those shoes steel toed Gotta love DIY work gear My wife always asked me why the heck do I where sandels when working with wood
beautiful build!! Im really regretting not buying a couple of Mal-x on July 4th weekend!!
post #13 of 161
Are those shoes steel toed Gotta love DIY work gear My wife always asked me why the heck do I where sandals when working with wood
I just wear some old new balances during most of the woodworking. I did wear some sandals during the sanding/priming though. Its warm down here.
Thanks, and you def should enjoy the Maelstroms.
post #14 of 161
Love the look of the red so far. Can't wait to see the finished product...and hear your impressions.
Need to get a free weekend so that I can get my 2 Maelstroms out of their cardboard boxes and into some proper MDF boxes!
post #15 of 161
No magnet braces?
post #16 of 161
I really wanted a Midnight Blue type of color, but Lowes/HD don't have a wide selection of spray paints. Down the road I'll just go with custom paint and a HVLP system. The red was my secondary choice but I think it will look nice (for paint anyway).
We got some auto body filler to work on the 'problem' areas and another can of primer and paint. Should have the whole thing finished tonight...just need to finish this prep work then put on ~3 coats of paint. I am not going to rush with the paint though. I want it to dry well before I start messing with the cabinet.
Meanwhile, here are 2 pics of the Dayton premium binding posts and plate that I picked up for this project.
post #17 of 161
Originally Posted by Looneybomber View Post
No magnet braces?
Nope.
post #18 of 161
Magnet braces...LOL The magnet must be fully supported by the basket. No need for any magnet braces...not like the 50000 metric T weight will cause the voice coil in the gap to shift.
post #19 of 161
Nice looking design and execution. I appreciate the utilitarianism and simplicity.
post #20 of 161
All done!
That 27" CRT is soon to be replaced by a 96"-100" projection screen. That is the next project (already have the Mitsu HC1500).
post #21 of 161
Just realized (and forgot) I am gonna need another RCA-XLR adapter since I'll be running both subs off the amp for a while.
post #22 of 161
Are the left/ right on the wrong sides?
post #23 of 161
I actually need to check with some other ZDT3 users or Zaph on that. I originally had them the other way around but in some of his pics I saw otherwise.
post #24 of 161
Will, that burgundy looks nice! I think it fits in with the mains better than would a dark blue.
Every little bit helps. Plus you can couple the motor to the brace and the brace to the rear wall, disipating vibrations to all walls. I should post pictures of my SDX sealed build...even though I've not done any finishing work on it, it's just nude plywood.
post #25 of 161
gaddam! that was quick....and beautifully executed!
that red finish really accents your room! Now build the second one, add some good power, a deq2496, and you will be in pretty nice shape my friend!
post #26 of 161
Will, that a beautiful and simple build. Very well done and I do like that Red color too!
any measurements or initial impressions?
btw, I love my little sealed sub too. I actually turn off my twin ported subs when listening to music.
post #27 of 161
BTW, to mount the driver I used the two pieces of wire through four mounting holes technique. It worked really well. That is how I will do it in the future.
Thanks Looney! You're right. It matches the room better in general.
Didn't seem so quick. Thanks Sherv.
Indeed. That is a likely scenario....we'll see.
I took some quick measurements with REW. It rolls off slowly until 20Hz, then falls quickly, but even my TC2K doesn't extend much more than that. I suppose after it breaks in it'll look even better on the low end. In its current placement I have a bad dip in the 65-75Hz area. But I feel that the extension is enough for music.
So far, sounds great. Blends in well. I have to hit the sack soon (get up at 6AM). Can't wait to get the TV/stand and equipment rack out of here so I have more flexibility with placement.
post #28 of 161
buy another Mal-x, I will buy your TC2K
post #29 of 161
Do you really need mine?
post #30 of 161
lol, do not really need it but I have two TC2Ks ported, one Sealed so another sealed one would be cool
